Results 1 to 8 of 8
    May 2023
    Default Mazda 3 Immo enable
    Hello All,
    I have Mazda 3 2008 1.6L PCM PN:z645-12A650-B
    my car has no immo by default, immo light in the dash is not blink or appear by anyway but when tried to make dash test it appears and immo coil antenna was not installed.
    I mange to get used coil antenna and installed it and get 2 transponders and using forscan tried to program them but it keep saying service interrupted and seems it is disabled in PCM or dash.
    how can I enable the Immo functionality, What need to be change?, Is there specific data need to write in EEPROM to enable it?
    kiszka's Avatar
    Quote Originally Posted by YAli View Post
    Hello All,
    read the eeprom of ecu and dash
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  3. The Following User Says Thank You to kiszka For This Useful Post:
    YAli (3rd June, 2023)
    May 2023
    Here is the two files, I was able to make the cluster work and program 2 keys but I got U2510 and car still start with any key
    kiszka's Avatar
    https://mega.nz/file/F2xnRSCC
    Reality of life :
    4:Everyone lies
  6. The Following 2 Users Say Thank You to kiszka For This Useful Post:
    YAli (12th June, 2023)
    May 2023
    Hello again,
    I was able to sync dash and PCM and no DTC and Immo light goes off and everything seems to be ok but the car won't start even I don't hear humming when I put key to ON seems that there is no signal to fuel Pump.
    I tried to give signal to fuel pump manually to the relay and it works so it seems that PCM is disabling it.
    Here is EEPROM for PCM can you check it
  8. #6
    kiszka's Avatar
    Hello again,
    looks like it's a different car so give me a dash reading as well
    Reality of life :
    4:Everyone lies
  9. #7
    May 2023
    It is the same car but using forscan I write the correct VIN block and make PATS module initialization
    After doing that P1260 has gone and it is cranking but no start
  10. #8
    kiszka's Avatar
    how many keys you have programmed
    Reality of life :
    4:Everyone lies
