Results 1 to 8 of 8
    Nov 2022
    Default FK72-14F041-AC BCM virgin dump neded Discovery Sport L550
    If anyone can help, I am ready to pay. Even non virgin dump kit welcomed. Even FK72-14F041-AD or AE part number are fine. I am also ready to exchange virgin dump for latest Evoque GJ32-14F041-AC
    Thank you
    Nov 2022
    Noone? I am offering in exchange the virgin untouched full read of the BCM for the Range Rover Evoque 2016+ part number GJ32-14F041-AC
  3. The Following 2 Users Say Thank You to ukautolocksmith For This Useful Post:
    BestElectrical (2nd August, 2023), Thatotherguy (22nd July, 2024)
    BestElectrical's Avatar
    San Diego, CA, USA
    Hi, can I get pass for the link, thank you!
    Hi, Could you help with a problem i have Same module but looks like it is corupt. I also have a donor one with AB suffix.
    I am only able to read P Flash with VVDI (On donor, not tried Ori yet) but it does not detect D Flash or Eeprom and is saying partition information error please entre partition size manually.
    Micro is 9S12 XEP100
    Mar 2021
    Cape Town, South Africa
    can i get a pass for the link above?
    many thanks!
    Hayssam1's Avatar
    Germany
    Quote Originally Posted by Thatotherguy View Post
    many thanks!
    NO PASS https://www.digital-kaos.co.uk/forum...=1#post4315464
    Please Press Thanks Button and Reput if i helped !
  8. The Following User Says Thank You to Hayssam1 For This Useful Post:
    iooloo (5th August, 2024)
  9. #7
    marsete's Avatar
    Oct 2010
    SPAIN
    Quote Originally Posted by accchris View Post
    Hola, ¿podrían ayudarme con un problema? Tengo el mismo módulo, pero parece estar dañado. También tengo un módulo donante con sufijo AB.
    Solo puedo leer la memoria Flash P con VVDI (en el donante; aún no he probado Ori), pero no detecta la memoria Flash D ni la EEPROM y me dice que hay un error en la información de la partición. Por favor, introduzca el tamaño de la partición manualmente.
    El micro es 9S12 XEP100.
    You introduce manual partition and read without problem is easy...Dflas 128 eeprom 16.
  10. #8
    Jan 2020
    Quote Originally Posted by ukautolocksmith View Post
    Password Please. Thank you.
