Hello!Fiat stilo 1.9 JTD not start.Diagnostic read stored error
"injector ECM capacitor 1".Problem to ECM EDC15C7.Please of help how repair EDC15C7.
Injectors on a diesel are operated with quite a high voltage (around 80 volt - eighty no mistake). This voltage is supplied by the ecu and the part is called a "capacitor". The ecu has 2 of them and number 1 has failed.
I saw on the internet site F-autronica.it - centro diagnosi elettronica dell'auto that often malfunction in the ECU EDC15C7 and be successfully repaired, but we found instructions on how repair fault so I asked if someone has repair guide how the failure to help me.
Sorry for my bad english
The problem is where will you buy the parts if these are made specifically for this ecu and are not normal parts that can be found on the market.
Bosch has a habit of using parts with a Bosch number on it, not the original manufacturer number. So, finding out what part it really is can be difficult.
Contact a professional ecu repair company like this one:
BBA reman. ABS, ecu's, throttle bodies, air mass meters, and catalytic converters
Non polarized capacitor 15uF 100v. you can buy it in a radio shack
Hello! I studied and improved ECU.Auto I was first starting out, such a mistake can be repaired successfully.
check the wiring. then check the injector resistance. should be about 0.50 ohms
Hi Dacha
Open your ecu and smell inside it if you noticed a strong smell inside it just check the capacitors and replace the worst one, I've had a similar case before and to be honest it wasn't so easy to solve the problem because of non original parts. But anyway if you find the correct one you just replace it and the problem is solved
Cheers
