Results 1 to 15 of 18
    Feb 2020
    england
    Default Mitsubishi Lancer 2008 2.0 di-d gs4 remap options?
    hi all, i'm hoping to remap my own car and then maybe my van, i have a kess v2 master and ksuite 2.80 and have already downloaded my car. I would definitely like to get rid of the egr, and add a little power which i know are possible, what i dont know is what else i could possibly change or enhance. The car has a turbo protection feature, basically i have no turbo until the car warms up and it is starting to irritate me, is it possible to remove this? the car also has an asc fault (low voltage detected, common fault) i also wonder if anything can be done with that although i am doubtful, i am capable of removing the pump and hot air soldering under microscope but i dont know what im doing with the repair people are charging fortunes to rectify, guessing i only need to replace a resister on a voltage divider but i dont actually know and cant seem to find confirmation, loathed to remove it just to have a look what i can do, and then have to bleed the brakes with no pit or ramp.
    I am happy to pay for my files to be edited but i dont want to be paying fortunes for something i probably once had, i did download the terebyte damos pack once upon a time and probably still have it if i go hunting, any recommendations would be gratefully accepted, i live near rochdale and would happily go somewhere local if anybody would help me out, please just let me know where and what its costing me.
    Thanks in advance.
    Edit, correction, its a GS3
    Aug 2014
    upload original file
    Feb 2020
    england
    Quote Originally Posted by lsdlsd88 View Post
    I hope i have done this right.
    Feb 2020
    england
    Assuming i have done something wrong, would love to know where im going wrong.
    Aug 2014
    sorry didnt see notification
    here u go try this sent u pass
  6. The Following 2 Users Say Thank You to lsdlsd88 For This Useful Post:
    lordtricky (29th July, 2023)
    Aug 2014
    Quote Originally Posted by lordtricky View Post
    the protection is there for a reason. yes u can go a little faster than factory but do not start the car and go 100% before oil is warm up (oil takes more time than water).
    check also if thermostat is working right!!
  8. The Following User Says Thank You to lsdlsd88 For This Useful Post:
  9. #7
    Feb 2020
    england
    Apologies for my delayed response, but many thank yous for the file, i have only downloaded it last night and expect to be trying it out next week after after the car has been for a service with cambelt. I will report back when i've tried putting it on the car.
    I know its a safety feature, but its a little dangerous first thing in a morning. Good call on the thermostat though, i may just have that swapped while theyre doing the water pump and cambelt.
  10. #8
    Feb 2020
    england
    UPDATE
    The car has now had a water pump, cambelt and service. I have just uploaded the file to my car and it seems to have worked, the car certainly feels a little more powerful although i did only fly around the block.
    Thank you so very much for the file modification, i am more than greatful but i still wonder what else can be done to it haha
  11. #9
    Aug 2014
    next step is get an obd scanner and datalog live data.. boost/fuel pressure, MAF, injection quantity, and so on
  12. #10
    Feb 2020
    england
    interesting you say that, i already have a delphi multiplexer for my laptop, and the car has a 10" android screen with a bluetooth elm 327 and torque lite, pretty sure i have all those in torque lite but not so sure how to actually datalog rather than just read live data if that makes sense. please educate me, is my equipment up to scratch? do i need to purchase anything new, can you recommend a better android app please?
  13. #11
    Aug 2014
    torque can take a recording. not sure if you need the pro version but definitely worth it.
    look inside the menu somewhere for "list of parameters to record"..
  14. #12
    Feb 2020
    england
    Apologies once more for such a delayed response, i have finally got torque pro and successfully made a datalog albeit eventually, am i on the right track with the following log please? This cant be used for any further modification though, the car currently has a leaking air filter so readings will be way off. I will sort the air filter out and take a full log of 20 mins driving one day next week and report back.
    Device Time, G(x), G(y), G(z), G(calibrated), Engine Coolant Temperature(°C),Engine Load(%),Engine RPM(rpm),Fuel flow rate/hour(gal/hr),Fuel flow rate/minute(gal/min),Intake Air Temperature(°C),Intake Manifold Pressure(psi),Mass Air Flow Rate(g/s),Turbo Boost & Vacuum Gauge(psi)12-Aug-2023 16:08:44.474,0,0,0,0,67,12.94117641,831,-,-,26,15.37400023,15.18999958,0.6740002
    12-Aug-2023 16:08:45.450,0,0,0,0,67,12.94117641,831,-,-,26,15.37400023,15.18999958,0.6740002
    12-Aug-2023 16:08:46.490,0,0,0,0,67,12.94117641,833,0.45846971 ,0.00764116,26,15.37400023,15.13000011,0.6740002
    12-Aug-2023 16:08:47.448,0,0,0,0,67,12.94117641,833,0.45846971 ,0.00764116,26,15.37400023,15.13000011,0.6740002
    12-Aug-2023 16:08:48.456,0,0,0,0,67,12.94117641,833,0.45846971 ,0.00764116,26,15.37400023,15.13000011,0.6740002
    12-Aug-2023 16:08:49.446,0,0,0,0,67,12.94117641,833,0.45846971 ,0.00764116,26,15.37400023,15.13000011,0.6740002
    12-Aug-2023 16:08:50.447,0,0,0,0,67,12.94117641,833,0.45846971 ,0.00764116,26,15.37400023,15.13000011,0.6740002
    12-Aug-2023 16:08:51.450,0,0,0,0,67,10.98039246,1033,0.7311879 9,0.01218647,27,17.11445308,24.12999916,2.41445303
    12-Aug-2023 16:08:52.456,0,0,0,0,67,10.98039246,1033,0.7311879 9,0.01218647,27,17.11445308,24.12999916,2.41445303
    12-Aug-2023 16:08:53.449,0,0,0,0,67,10.98039246,1033,0.7311879 9,0.01218647,27,15.22896249,24.12999916,0.52896249
    12-Aug-2023 16:08:54.450,0,0,0,0,67,12.94117641,828,0.45034623 ,0.00750577,26,15.22896249,14.93999958,0.52896249
    12-Aug-2023 16:08:55.445,0,0,0,0,67,12.94117641,828,0.45034623 ,0.00750577,26,15.22896249,14.93999958,0.52896249
    12-Aug-2023 16:08:56.444,0,0,0,0,67,12.94117641,828,0.4660452, 0.00776742,26,15.37400023,15.38000011,0.6740002
    12-Aug-2023 16:08:57.444,0,0,0,0,67,13.33333302,832,0.4660452, 0.00776742,26,15.37400023,15.38000011,0.6740002
    12-Aug-2023 16:08:58.445,0,0,0,0,67,13.33333302,832,0.4660452, 0.00776742,26,15.37400023,15.38000011,0.6740002
    12-Aug-2023 16:08:59.446,0,0,0,0,67,13.33333302,836,0.45839398 ,0.0076399,26,15.37400023,15.10999966,0.6740002
    12-Aug-2023 16:09:00.447,0,0,0,0,67,13.33333302,836,0.45839398 ,0.0076399,26,15.37400023,15.10999966,0.6740002
    12-Aug-2023 16:09:01.445,0,0,0,0,67,13.33333302,836,0.45839398 ,0.0076399,26,15.37400023,15.10999966,0.6740002
    12-Aug-2023 16:09:02.448,0,0,0,0,67,0,3475,2.51949851,0.041991 64,26,17.98467951,83.05000305,3.28467941
    12-Aug-2023 16:09:03.444,0,0,0,0,67,0,3475,2.51949851,0.041991 64,27,17.98467951,83.05000305,3.28467941
    12-Aug-2023 16:09:04.444,0,0,0,0,67,0,3475,2.51949851,0.041991 64,27,17.98467951,83.05000305,3.28467941
    12-Aug-2023 16:09:05.444,0,0,0,0,67,12.94117641,826,0,0,27,15. 22896249,15,0.52896249
    12-Aug-2023 16:09:06.444,0,0,0,0,67,13.72549057,829,0.46046036 ,0.00767434,27,15.08392475,15.15999985,0.38392472
    12-Aug-2023 16:09:07.444,0,0,0,0,67,14.11764717,826,0.46046036 ,0.00767434,27,15.08392475,15.15999985,0.38392472
    12-Aug-2023 16:09:08.450,0,0,0,0,67,14.11764717,826,0.46046036 ,0.00767434,27,15.08392475,15.15999985,0.38392472
    12-Aug-2023 16:09:09.444,0,0,0,0,68,14.11764717,828,0.46285205 ,0.0077142,27,15.37400023,15.22000027,0.6740002
    12-Aug-2023 16:09:10.447,0,0,0,0,68,13.33333302,828,0.46285205 ,0.0077142,27,15.37400023,15.22000027,0.6740002
    12-Aug-2023 16:09:11.451,0,0,0,0,68,13.33333302,828,0.46285205 ,0.0077142,27,15.37400023,15.22000027,0.6740002
    12-Aug-2023 16:09:12.444,0,0,0,0,68,13.33333302,831,0.46264122 ,0.00771069,27,15.37400023,15.25,0.6740002
    12-Aug-2023 16:09:13.445,0,0,0,0,68,13.33333302,827,0.46415803 ,0.00773597,27,15.37400023,15.30000019,0.6740002
    12-Aug-2023 16:09:14.451,0,0,0,0,68,13.72549057,831,0.45043717 ,0.00750729,27,15.37400023,14.82999992,0.6740002
  15. #13
    Aug 2014
    air filter isn't gonna affect it much. upload the file you get directly from torque folder to the forum as attachment
  16. #14
    Feb 2020
    england
    i will try again, but the forum said invalid file type. I just assumed it didnt like .csv and didnt think to zip it, its been a long week
  17. The Following User Says Thank You to lordtricky For This Useful Post:
    lsdlsd88 (13th August, 2023)
  18. #15
    Aug 2014
    log is kinda readable.
    sample rate is unusably slow though, so try to get rid of all parameters and just put RPM/intake manifold pressure/mass air flow rate.
    get the car hot ( in the log it was only 67C!) then start log, do a simple full throttle run from 1500 to redline then stop log.
    in a high gear depending on speed u can do in your area.. the higher the better cause parameters change slowly so its not too fast for the logging to keep up.
