Results 1 to 2 of 2
    Feb 2014
    Default FoxFlash repair ftdi-blank !!!!!
    If your Foxflash only shows USB serial to converter, ftdi is probably deleted.
    That was exactly the problem with me. Many people are experiencing the same problem but there is no solution even from the manufacturer.
    It is solved in several steps.
    For starters, we're using FGtech's .ept file
    After the last step, launch FoxFlash........
  2. The Following 6 Users Say Thank You to SonyPS3 For This Useful Post:
    banza (17th June, 2023), djamel30 (26th December, 2024), EmmTo (25th August, 2024), hbalazs (17th June, 2023), stefaudio (17th June, 2023), tomasz2424 (16th June, 2023)
  3. #2
    Did you read forum rules???
    Here is English not cyrylic
