Need adblue off Ford transit 2020 SID212+DCU17PC43 scr ecu DCU17PC43 MCU TC1724
This car need to do scroff in dcu only . What error you have ?
File Service ----- Custom Files ------ DPF / SCR / EGR / TVA / Stage ...... Immo / Airbag ETC
Manual File Service WITHOUT prepaid
I know that only in DCU.
Now error P2BA9 - excess NOx - insufficient quality of the reagent.
On the instrument panel - "engine will be blocked after 50 km"
I'll pay your price if the solution works. I tried many solutions - everyone assured me that 100% - none of them worked
DCU17PC43 AdBlue off solved with disabled urea injector and pump.
WinOLS5, custom files for ECU DCU
Help with shutdown on this car, I'll pay. No one can, tried several options
ps Everything is very simple in words, but in reality the car is still standing and not one solution has helped
From what I understand - all solutions are designed for a fully serviceable car without errors. If there are errors and the motor is blocked, then after unlocking, you need to repair the SCR system, and then turn it off. Or you need to fix the eeprom and flash, otherwise nothing will workEverything is very simple in words, but in reality the car is still standing and not one solution has helped
wrtie to me skype: xxxxxxxxx!!!
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
test and report
Mexaniks (1st July, 2023)
Good morning, I have a similar problem, but with other fault codes, limited van but I cannot permanently erase these faults. I attach a photo. all the best
