Results 1 to 13 of 13
Thread: Matiz immo off
    Oct 2017
    Hungary
    Default Matiz immo off
    Hello masters!
    I would like to turn off the immo in the Daewoo Matiz engine control.
    I read on the forum that DATA EXPLORER MANAGER does it, but I couldn't download it.
  2. The Following User Says Thank You to sancaman For This Useful Post:
    danielif (24th June, 2023)
  3. #2
    Oct 2017
    Hungary
    I found a solution in the CARLABIMMO program.
    Nov 2017
    Dobruja
    Sanca, arya ok, man? The ovoid thells you about an emulator, i guess. I know there is a solution for immo off in ecu, but was 20euro on a site...
    Oct 2017
    Hungary
    If we try it, I'll tell you if it's good or not.
    Nov 2017
    Dobruja
    Data Explorer Manager does Rolling code reset only, not total immo off.
  7. The Following User Says Thank You to volodin69 For This Useful Post:
    sancaman (22nd June, 2023)
  8. #6
    Oct 2017
    Hungary
    The car started. Immo box removed.
  9. The Following User Says Thank You to sancaman For This Useful Post:
    volodin69 (22nd June, 2023)
  10. #7
    Nov 2017
    Dobruja
    Thanks! Good to know that.
  11. #8
    Feb 2015
    GREECE
    with carlabimmo emulator?
  12. #9
    Feb 2015
    GREECE
    Quote Originally Posted by sancaman View Post
  13. #10
    Oct 2017
    Hungary
    Without emulator. Flash programming only.
  14. #11
    Feb 2015
    GREECE
    can you give me the flash with immo off please?
  15. #12
    Oct 2017
    Hungary
    Change the data to 4000-7FFF
  16. The Following User Says Thank You to sancaman For This Useful Post:
    speedservice (27th June, 2023)
  17. #13
    Oct 2017
    Hungary
    Default IMMO OFF
    Here is the file. Good luck.
  18. The Following 2 Users Say Thank You to sancaman For This Useful Post:
    ese167 (6th September, 2024), panos_k (13th June, 2024)
