Results 1 to 8 of 8
Thread: Eurovox Manual
    Oct 2008
    Default Eurovox Manual
    Hi Guys
    Cant anyone tell me where I can get hold of a Eurovox Manual.
    Been trying for days to set up box, must have missed a step somewhere. Pluged the rf cable in but a message appears saying no channel selected. It is on the same channel as my cable. Performed manual tuning on tv and can pick up normal terrestial channels but no cable. Box performs channel search. Strength & Quality are both High.
    Cheers
    Administrator
    Devilfish's Avatar
    Feb 2008
    Check out the sticky threads in this section, the ones in red, they might be able to help you out.
    V.I.P. Member HiTeck's Avatar
    Oct 2008
    I have just uploaded this aswell, hope it helps out.
    Digital Kaos - Downloads - Eurovox Max Manual
    satsmo's Avatar
    Jun 2008
    Thought you gave it to him already
    Oct 2008
    You get around I may have but was a different username.
    satsmo's Avatar
    Jun 2008
    Same guy different coat
    Oct 2008
    Default Thanks Guys
    Thank you all very much for the support. After spending a few hours the box is working fine some channels scramble but really happy now.
    This is a wonderful site and can't you guys enough for the quick and excellent support.
    Yes you did pass on the manual to me but I needed to go to downloads/firmware to get the pdf file, which is what I really wanted.
    Next question does the box work well using a splitter?
    Many Thanks
    Lord_Cardiff
    Oct 2008
    Some are ok some are not, depends on your signal strength and quallity of splitter, try it and see, if your having problems with it take it out.
