Results 1 to 15 of 16
    Mar 2022
    Default need VW t4 immo off
    Hello. need immo off VW t4 2.5 TDI. ECU Bosch 0 281 001 640. VW 074 906 021 L. What chip to read for immo off? On one side there are B57496 14leg eeprom and other side TL B57934 14 leg chip and 8 leg chip 30281 M3725 A3824 and 14leg SIEMENS B58290.
    And can anyone help with immo off file?
    marina_rv's Avatar
    Ukraine
    please press the little THANKS
    Mar 2022
    Can anyone help with immo off? File in attachment.
    eliet2000's Avatar
    Sep 2011
    Pixa-Roglet / Valencia / Spain
    Quote Originally Posted by matur View Post
    Post your dump
    Pepelno Vds Pro
    Mangarrufa Power Solutions
    thank you is free
    Mar 2022
    here is dump sir
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    here is dump sir
    Please................
    Disconnect the immo box
    PLEASE PRESS THE " THANKS " BUTTON
  7. The Following User Says Thank You to gwiazdamb For This Useful Post:
    matur (24th July, 2023)
    Mar 2022
    solution no work sadly. now no fault code for immo but car starts and dies after 4 sec.
    Mar 2022
    can anyone help with immo off??
  10. #9
    Mar 2022
    I tried with immo Box connected also. Still no fault code but car dies after 2 sec.
  11. #10
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Save this file disconnect immo box
  12. #11
    Mar 2022
    Car sputters, no start. Immo fault code...
  13. #12
    Nov 2017
    Dobruja
    Try and report. If it does not work, you might be having another problem.
  14. #13
    Mar 2022
    Car sputters a little but wont start. No fault code...
    I also dont have immobox, instead of immobox there was an emulator but that burned out and now have this immo problem. Before emulator burn car all start 100%.
    I also dont know why but everytime when i write a dump to eeprom and try to start the car and then read the dump again, it has changed. I attach for example after trying your file what the file looks like after starting the car.
  15. #14
    Nov 2017
    Dobruja
    Ok. Need to wp it... Write immo off dump. Lift pin No.7 and solder it to pin 8. Or put again the emulator.
  16. #15
    Mar 2022
    Lift pin 7 where? eeprom chip? WP as in what?
