Results 1 to 7 of 7
    UA
    Default Honda Accord 2001 SRS wiring diagram
    Hi guys!
    I need wiring diagram of the SRS system on Honda Accord 2001-2002.
    SRS unit 77960-s1a-g94-m1 with two sockets, two airbags.
    Can`t find nowhere it. I hope very much for your help
    Thanks!
    Ashraf6119's Avatar
    UK
    What is the fault on this car
    Have a look on Tolerance Data you will find in there
    Ash
    bram380's Avatar
    Indonesia +628153111774
    Quote Originally Posted by DarkDiver View Post
    Hi guys!
    Thanks!
    This civic 2002-2003
    UA
    Quote Originally Posted by Ashraf6119 View Post
    Ash
    Thanks for the tip. Indeed, in the Tolerance Data is what I need.
    In the car passenger airbag worked, I want to erase the crash from the SRS unit. I bought Honda Airbag Reseter for TMS320 but it does not work directly on the car. Will try to connect reseter directly to the unit.
    Ashraf6119's Avatar
    UK
    TMS320 should work fine just plug into OBD plug than put the ignition switch to ON position for 5 Seconds you will hear some clicking noise than Switch Ignition OFF.
    Ash
    UA
    When turn the ignition nothing happens. Only the one beep sound when I plug it into a OBD. Interestingly, diagnostic scanner any errors does not show, although the SRS light is on.
    Ashraf6119's Avatar
    UK
    Have you tried to Disconnect the battery for few min and Connect it again and see whats happening.
    Ash
