Results 1 to 3 of 3
    Nov 2018
    Default Ford Transit 2007 SID206 Injector fault - no start
    Hello i have Ford Transit with SID206 ecu, no signal going to injectors. Does someone know which chip/chips inside the ECU controls the injectors? Or is it just better to get replacement and clone?
    Thanks in advance.
    Hayssam1's Avatar
    Germany
    Quote Originally Posted by munkss View Post
    Thanks in advance.
    P062D Fuel Injector Driver Circuit Performance Bank 1 or P062E !!Ford ecosport "Hyundai" "Ford"
    https://youtu.be/HVK2OW4Axi8
    Please Press Thanks Button and Reput if i helped !
  3. The Following User Says Thank You to Hayssam1 For This Useful Post:
    munkss (18th August, 2023)
    Nov 2018
    Quote Originally Posted by Hayssam1 View Post
    Saw the video but did not really understand much. I've located 4 mosfets that control injectors but they seem fine. So im guessing there is a larger problem with the ECU probably better to get a replacement and clone it. But thanks for input.
