Results 1 to 12 of 12
    renia1983's Avatar
    Jun 2022
    Default Mitsubishi MUT-3 SE with Scanmatik FOR FREE!
    I've managed to make my Scanmatik work with MUT-3 SE! - I think same solution will work for other J2534 devices!
    Not sure about 100% functionality but no problem with coding in ETACS and done lots of diagnostics!
    You need MUT-3 SE version (it supports J2534) - 21061 and 22030 are available out there. NO - MUT-3 is not working!
    After installing whole package, make sure to install:
    - driver from VCI3 folder (it's in MUT-3 package)
    - driver for Scanmatik
    Open regedit and go to: HKEY_LOCAL_MACHINE -> SOFTWARE -> Wow6432Node
    In PassThruSupport
    in Vendor1 - change Name to Bosch
    in Device1 - change Name to RNM-VI
    In PassThruSupport.04.04 in Scanmatik - SM2 USB - change Name to RNM-VI and Vendor to Bosch
    in Bosch - RNM-VI - change ConfigApplication and FunctionLibrary to ones you got under Scanmatik - SM2 USB
    In PassThruSupport.05.00 in Bosch - RNM-VI - change ConfigApplication and FunctionLibrary to ones you got under Scanmatik - SM2 USB
    I attach screenshots how it looks in my registry.
    Hope you like this MOD
    IF YOU TRIED THIS ON OTHER J2534 DEVICE, LET US KNOW IF IT WORKED!
  2. The Following 19 Users Say Thank You to renia1983 For This Useful Post:
    aams (12th March, 2025), asawin999 (21st April, 2024), daniersms (23rd August, 2023), dimaukraina (20th December, 2023), dule14786 (22nd August, 2023), EduardNN (25th April, 2024), fuzz1 (19th December, 2023), hercamp (26th December, 2023), jo?o antonio (27th November, 2023), Krisz1111 (23rd April, 2025), NiMh (23rd April, 2025), papa (29th October, 2024), shittu191 (7th January, 2024), siewcu (28th August, 2023), torzet (24th August, 2023), Wsergik (20th November, 2024)
  3. #2
    Oct 2023
    I can test on mini VCI and Openport
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by ker0de View Post
    Have you tried? What is the outcome?
    Oct 2023
    sorry mate, away for a couple weeks, so can't try until I get back unfortunately
    Aug 2012
    what version of windows?
    Aug 2012
    And 32 or 64?
    Aug 2012
    I tried it on Windows 7 32 bit, and vas 5054. The program sees the adapter, but there is no connection with the car
    Aug 2012
    Windows 7/64 and Scanmatic 2 Pro can be seen by the program. I haven't tried it on a car yet
  10. #9
    Aug 2012
    works. sm2 pro + mut-3 se
  11. The Following User Says Thank You to dimaukraina For This Useful Post:
  12. #10
    Aug 2012
    W7 32 also work
  13. #11
    fuzz1's Avatar
    Jul 2019
    Anyone tried with tactrix open port?
  14. #12
    Feb 2019
    hi, have L200 2002 115 CV not connect with car, use sm2 pro. MUT 3 SE not work with k-line? for test interface? If use scanmatik ok
