Results 1 to 13 of 13
    Paris
    Default mercedes c klasse EZS W203 dump needed HC12 3K91D
    I lost MCU data for c class w203 2003 HC912DG128 Mask 3K91D QFP112 Part # EZS 2095450508 (ezs inscription: W211_HC12), the car doesn't start and no response when key inserted into EZS.
    Please anyone could help me sending EZS dump: eeprom & flash for MCU so i can recover ezs data when generating new bin files from EZS (you provide) and existing ESL/ECU.
    Thanks a lot.
    Jakarta, Indonesia
    Quote Originally Posted by kanzus View Post
    Thanks a lot.
    you send all data, EIS and ecu..pls
    DK Veteran deffc0n's Avatar
    UK/POLAND
    This EZS ?
    Paris
    Quote Originally Posted by deffc0n View Post
    This EZS ?
    link pic you sent is down.
    Jakarta, Indonesia
    sorry data.. close
    Paris
    Quote Originally Posted by bali motor View Post
    this HC12 dump eis and key.
    Thanks for post, but file you sent is for ST 9S12 MCU, I need file for HC 912 MCU.
    Do you have that HC dump please ?
    Jakarta, Indonesia
    this HC12, it work for me..
    Paris
    Thanks a lot.
    Will try it, and keep u informed ;-)
    Paris
    I desolder HC912DG128 from eis, and use Omega programmer, do you think that i program it directly without file conversion ?
    Please advise.
    Paris
    Quote Originally Posted by Carsmi1985 View Post
    ?? what's up ??
    Paris
    Omega programmer does not read HC912DC128A mask (3K91D), I think because there is no hpx file for 912DC128, there is only for 912DG128.
    I tryed with ETL programmer 912: at the begining I had problem reading eprom & flash, i got error message; I check again soldering, then 912 programmer read OK, so I saved flash and eprom, then erase eprom and program OK.
    Thanks Baly Motor for dump, it helps me a lot, i prepare EZS, ESL and Keys, i'll try it this evening.
  13. #13
    Could anyone help me sending EZS dump: eeprom & flash for MCU
    I've bought AK500 recently and tested it on w210 and w203. Now I've had 2 big problems : 2 cars doesn't start.
    w203 ezs 2095450508 HC912DC128A mask (3K91D), like kanzus, esl 203 4pins, ecu siemens5wk90479(am29f800bb)
    I strongly need dump for HC912DC128A mask (3K91D), can anybody help me?
    about w210 next time
