Results 1 to 12 of 12
    badziewo's Avatar
    Feb 2016
    Universe
    Default ECU cloning 2012 Audi Q5 8R0-907-115P MED17.1
    Hello Lads.
    I have 2012 Audi Q5 8R0-907-115P MED17.1 with
    faulty ECU – not accessible by OBD.
    I was able to read it with Ktag.
    Also I purchased used same ECU.
    After cloning it I’m not able to start the car.
    Two codes are present:
    1- 2783 - Internal Control Module Memory P160A 00 [167] - Check Sum Error
    2- 02241 - Engine Control Module; Immobilizer Data not Adapted
    Is there anything else I should do before transfer files from faulty ECU to
    donor ECU?
    If yes then help me to modify the file please.
    Files attached
    Any help is appreciated.
    IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
    Jul 2019
    Denmark
    I no one is faster I can do when getting home..... if you can't wait try just flashing eprom again or desolder and resolder eprom from broke ecu to good ecu
    eliet2000's Avatar
    Sep 2011
    Pixa-Roglet / Valencia / Spain
    Quote Originally Posted by badziewo View Post
    Hello Lads.
    donor ECU?
    Files attached
    Try this file
    Pepelno Vds Pro
    Mangarrufa Power Solutions
    thank you is free
  4. The Following User Says Thank You to eliet2000 For This Useful Post:
    badziewo (29th August, 2023)
    Hayssam1's Avatar
    Germany
    Hello Lads.
    donor ECU?
    Files attached
    VIN: WA1LFCFP8CA127816
    CS: C9E8D4E7F4AFAB
    MAC: 1553F877
    PIN: 61767
    Please Press Thanks Button and Reput if i helped !
  6. The Following User Says Thank You to Hayssam1 For This Useful Post:
    badziewo's Avatar
    Feb 2016
    Universe
    Quote Originally Posted by Hayssam1 View Post
    CS: C9E8D4E7F4AFAB
    MAC: 1553F877
    PIN: 61767
    Thanks my friend.
    Car doesn't start and code 02241 - Engine Control Module; Immobilizer Data not Adapted present.
    Any other option?
  8. #6
    Hayssam1's Avatar
    Germany
    Thanks my friend.
    Any other option?
    Try this file
    immo off
  9. The Following User Says Thank You to Hayssam1 For This Useful Post:
    badziewo (30th August, 2023)
  10. #7
    badziewo's Avatar
    Feb 2016
    Universe
    Quote Originally Posted by eliet2000 View Post
    Try this file
    Thank You for your help but car doesn't start.
  11. The Following User Says Thank You to badziewo For This Useful Post:
    eliet2000 (30th August, 2023)
  12. #8
    badziewo's Avatar
    Feb 2016
    Universe
    Try this file
    immo off
    Thank you. Your files worked good. Car starts. There is code P160A00 Faulty Control Module and I can't delete it. Do you know how to get rid of it?
  13. The Following User Says Thank You to badziewo For This Useful Post:
    Hayssam1 (30th August, 2023)
  14. #9
    Hayssam1's Avatar
    Germany
    P160A00 ===>> control module defective.
    please write what i sent to you in the first file
    so only EEPROM file because the
    Vin number is wrong
    I think for this engine control unit should only Flash immo off
  15. The Following User Says Thank You to Hayssam1 For This Useful Post:
  16. #10
    badziewo's Avatar
    Feb 2016
    Universe
    Hi.
    You are the man!!!
    The car works fine but I still have 2 errors
    1 - P1570 - Engine Start Blocked by Immobilizer
    In addition, the EPC light on the dashboard comes on.
    I have calibrated the throttle but the light is still on.
    Can you clear these 2 codes and help me solve the problem with the EPC light?
  17. #11
    alonedark's Avatar
    Feb 2017
    Because you don’t have inmo transfer you have inmo off ,,, if you don’t have toool for inmo transfer you can remove mcu tricore ori to donor Ecu
  18. The Following User Says Thank You to alonedark For This Useful Post:
    badziewo (31st August, 2023)
  19. #12
    badziewo's Avatar
    Feb 2016
    Universe
    Solved.
    Thank you all.
