Results 1 to 15 of 17
    super jumbe's Avatar
    Livingstone
    Default Nissan Juke 2010 pin code from glove box label not accepting AKL.
    Original Glove box label code 4ECD8F04567A
    The codes I got below not accepting can someone check which one is the right one.
    97654963AA21
    07654963AA21
    UK
    I'm getting 07654963AA21
  3. The Following User Says Thank You to the_big_d For This Useful Post:
    super jumbe (31st August, 2023)
    rm23's Avatar
    UK
    I am sorry to say that but akl is better to do by eeprom no by obd2, looks like bcm now is dead..
  5. The Following 3 Users Say Thank You to rm23 For This Useful Post:
    AOSHAMBURG (31st August, 2023), godfathertwo (30th August, 2023), super jumbe (31st August, 2023)
  6. #4
    May 2021
    These Nissan are Getting worse
    I hope is not a expensive Repair for the locksmith again.
  7. The Following User Says Thank You to godfathertwo For This Useful Post:
  8. #5
    p1et's Avatar
    Oct 2013
    Not necesseraly bricked. Some of the tools struggle with 12 digit Juke. Try OBDstar if you have, go through all systems.
  9. The Following 3 Users Say Thank You to p1et For This Useful Post:
    godfathertwo (31st August, 2023), musti418 (31st August, 2023), super jumbe (31st August, 2023)
  10. #6
    Livingstone
    Done thousands of jukes don’t know the history but this car was bought from auction will have a go again today nightmare with Nissan.
  11. #7
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by super jumbe View Post
    97654963AA21
    07654963AA21
    What system does this Juke have, blade key or proxy?
    It might look like this post:
    https://www.digital-kaos.co.uk/forum...ey+programming
    You need the right programmer for that,not every tool works at Nissan
    I had a case 2 years ago to add a blade key to a 2011 Juke:
    I had real help from some DK members to be able to choose the right solution and successfully overcome the difficulties
  12. The Following User Says Thank You to vialli For This Useful Post:
  13. #8
    May 2021
    They said obdstar worked on this model surely some other obd programmer should work have you tried truecode .
  14. The Following User Says Thank You to godfathertwo For This Useful Post:
  15. #9
    Livingstone
    I always use truecode first but now truecode online software has been a total failure, they need to update bugs otherwise I will not be subscribing next year, I used smart pro and done the job in 4min.
  16. The Following User Says Thank You to super jumbe For This Useful Post:
    godfathertwo (1st September, 2023)
  17. #10
    p1et's Avatar
    Oct 2013
    So what was the problem? You finished with Smart Pro using which PIN code?
  18. The Following User Says Thank You to p1et For This Useful Post:
  19. #11
    Livingstone
    Quote Originally Posted by p1et View Post
    Used smartpro with this pin code 07654963AA21, truecode was not accepting above both pincodes.
  20. The Following User Says Thank You to super jumbe For This Useful Post:
    PierreTheron (2nd September, 2023)
  21. #12
    Jan 2022
    Hi, I am auto locksmith since many years, last month we get a Nissan Juke 2012 AKL but can't finish the job and car go to Nissan. If you start the car, please tell us how?.
    We try to make the chip via eeprom (used chip 7936 ori, aftermarket, CN3, Xhorse XT27 and King chip).
    We buy a used BCM with key (car cranks but not start, try to adapt BCM with autel, stop cranks).
    Used tools: Avdi, OBDStar, Autel 508, Xtool Pad3, Lonsdor, Xhorse key tool plus
    At last, we send the car to Nissan they start the car and program a new key (no part changed ).
  22. The Following User Says Thank You to KeyCoche For This Useful Post:
    godfathertwo (3rd September, 2023)
  23. #13
    May 2021
    This is For Super Jumbe have you vontacted Chris so can fix this bug on Nissan thank you .
  24. #14
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by KeyCoche View Post
    Some tools struggle with Juke 12 digit PIN diesel system. If aftermarket tools does not work, need to use Nissan Consult. I don't touch these.
  25. The Following User Says Thank You to p1et For This Useful Post:
    godfathertwo (4th September, 2023)
  26. #15
    fred77's Avatar
    Jun 2019
    Had a 2014 4 digit Juke today
    Steering lock wasn't engaging and car wouldn't start after coding a spare
    Apart from that new key worked fine. Pee'd around for an hour with 2 new keys and eventually ok.
    worried for tad as seemed a Qashqai moment
    Solidarity with Ukraine
  27. The Following User Says Thank You to fred77 For This Useful Post:
    godfathertwo (7th September, 2023)
