Results 1 to 2 of 2
    srzar's Avatar
    Jun 2013
    Default WINOLS VMWARE COMPILATION 2.24 4.26 4.51 4.70
    hello
    thatīs my firsT contribution on forum,
    i hope you can learn to use winols and ecm to do a good job and play with original software
    I make a compilation in one post of every version i find on vmware images to can have all of them together in one pc and can work and correct checksums in the most possible ecus
    thanks to all the crackers, and contributors to that winols versions, thanks to their work, we have that compilation of vmware images for learners
    wy on vmware images? cause you cant use at same time two diferent versions installed on windows, and cause some of them not work very good and are better on vmware, that way every time you start the vmware image, winols works at 100%
    i found 2.24 4.26 4.51 and 4.70
    you can tell, i dont need more version than the most new...
    big error if you are free user, each cracked version haves different plugins enabled, then the only way to can do any ecu, is have all the possible versions with their different pluggins
    USE INSTRUCTIONS OF 4.70, FOR 4.51 AND 4.26
    i put the links and password on attachment
    ENJOY
    Last edited by srzar; 6th January, 2024 at 03:24 AM. Reason: Update link to winols folder easy to update :)
  2. The Following 7 Users Say Thank You to srzar For This Useful Post:
    aaltraz (6th March, 2025), F3N1X (14th February, 2024), Ivan99 (18th November, 2024), jonasg (4th March, 2025), Krisz1111 (7th March, 2024), RazzaMuffin (18th September, 2023), wecki2 (22nd October, 2024)
  3. #2
    Sep 2023
    I don't see a way to delete my post? My apologies. It was just a problem with the PC.
    Last edited by Crazy18T; 16th September, 2023 at 02:22 AM. Reason: invalid post due to PC problem
