Results 1 to 7 of 7
    Sep 2023
    Default Audi A4 B7 RB4 Cluster issue
    I have an Audi A4 B7 2007, 2.0 TDI BLB which originally had a red DIS RB8.
    I changed the cluster with a colour one, from an A4 B6, the RB4 type. Everything works fine, done IMMO Off with vvdi2 at a guy, new transponders syncronised, no errors, all is good.
    The single problem is that the temperature gauge not working. In output test, it s ok, but I assume it s something with the sensor, because the B7 has 2 pins and the B6 has 4. In Vcds, on the engine, the temperature is ok(on rb8 it showed temperature), but on the instruments, it reads -100 degrees. Can i do something to make the gauge work? Like moving a pin or smth.
    Any help is appreciated, thank you!
    Romania
    post eep from your rb4 dash
    Nov 2017
    Dobruja
    Maybe this helps...
    Sep 2023
    up please, i will try to make a wire from the sensor directly to the cluster
    Sep 2023
    immo rb4 eepr.zipthere it is
    Romania
    Try this and report
  7. The Following User Says Thank You to ghitab For This Useful Post:
    cataaa (13th January, 2025)
    Nov 2024
    Hi guys!
    I have the same situation, can someone help me, please, with the solution? ;-;
    A4 B7 2007 Colour Dash not showing coolant temp at all
