    Germany
    Default GOLF 6 03c906024bd need pin from ecu
    Hy i have an Golf 6 my original ecu was stolen so i bought second hand one but i need pin to adapt it to car .
    Epperom is M95320
    Thank you in advance
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by mm04kk View Post
    Epperom is M95320
    hi....
    try 56311.......
    Η κότα έκανε το αυγό ή το αυγό την κοτα;
    Germany
    Can someone give me virgin dump because i can not get my oeiginal pin from dash because immo is active
    Hayssam1's Avatar
    Germany
    try write pin cod 56311 from Panathaole three times while briefly turning the ignition off each time after three attempts the car will start
    or deactivates the immobilizer CUT Pin 19 Or wirite Protect 8C Secutity
    Please Press Thanks Button and Reput if i helped !
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    You cannot adapt ecu on immo4 system with pin code only.
  6. The Following 3 Users Say Thank You to lupu_sandu For This Useful Post:
    Hayssam1 (26th September, 2023), jokir (28th September, 2023), rafal (26th September, 2023)
    Germany
    i tried the pincode 56311 but its wrong ecu dont accept the code
