Results 1 to 8 of 8
    Belarus
    Default zafira GID unregistered
    Hi! I need unregistered 93c56 used display GID opel zafira. Old display won't turn on and no diagnostik.
    I replaced 93c56 old-->used display, but see DISPLAY SAFE. And please help with pin code this damp.
    WALES
    Quote Originally Posted by Jur View Post
    I replase 93c56 old-->used display, but see DISPLAY SAFE. And please help with pin code this damp.
    Post dump from original display also...
    and your donor dump is read incorrectly, too small, check settings
    wbr
    Belarus
    Donor damp read correctly. ST95C56 , vin in swap byte end damp. size 256b, 128x16. Original dump in attach. Original radio code in name file.
    WALES
    100% wrong read, your data is from 93C66 8bit chip
    wbr
    Belarus
    My data in ST93c56, 128X16. 100% GID Siemens, blue conector. See dump in hex editor.
    Other GID have 93c66 eeprom and other size dump (512b), and other structure dump. This GID opel Zafira B monohrom yellow, not Astra, Vectra.
    WALES
    PIN not even in that part of the data.....
    REALLY look at your chip, it says 93C66, post picture showing your chip.
    Just read as 93C66 and post it here.......
    wbr
    Here is an example of your file vrs 93C66:
    Belarus
    ok, ok, just later. In the evening.
    Belarus
    Sorry, but my client can't come yet. Let's leave the question open, but there is a high probability that I am wrong.
