VCDS Hex v2 clone repair (VAG) Full Package revoked license
VCDS 22.3.1 Hex v2 clone protection MULTILANGUE (VAG) Full Package license revoked VAG Package can convert a cheap VCDS Cable to ORIGINAL VCDS Cable and can run with any VCDS software version, even the last official VCDS Computer version V21.3.0 and comes new VCDS can continue to work with its software, also with the package. It contains many other ITEMs for VAG Cars, it includes the following contents: VCDS Clone To work with devices with the latest version of VCDS software 21.3.0 or higher The descriptions of these utilities based only on the ATmega162 chip were successful.
NEC, ARM or others are not supported! To detect if the bootloader is enabled on your current cable, run VAGCOM_HWType.exe and click the Read button. Both the computer USB port and OBD2 port (or 12V power supply) of the cable. It also shows the hardware type of the cable.
If the tool shows that the bootloader is enabled, you can update the EEPROM using VAGCOM_EEWriteLang.exe.
The default language is English, but includes a language available from the drop-down list below.
The VAGCOM_EEWriteLang.exe utility. If you speak any additional special language, the execution
The installation will be enabled for two languages: the selected language and also English.
Install official VCDS version 17.1.3, 17.8, 18.2, 18.9, 19.6 (or latest version 22.3.1),
Copy VCDS Lloader.exe to installed directory and shortcut on Desktop (and Start shortcut) will work each time to start VCDS Lloader.exe
Instead of the original shortcut to VCDS .exe. VCDS .exe will be renamed VCDS .exeL. Internet connection
It can stay ON. Antivirus, Anti-Malware or other similar software (including Windows Defender),
Exception expansion is required to replicate the installer replica.
