    macinek102's Avatar
    Feb 2019
    PL
    Default MD1 Toyota Proace Adblue OFF ( Peugot ECU )
    Hello friends, could someone help me remove ADBLUE from this ECU
    If I helped, press the Magic Button
    macinek102's Avatar
    Feb 2019
    PL
    Może ktoś sprawdził, co jest nie tak. Nadal będzie wyświetlać błąd ADBLUE.
    Please have a look at this. Tell me how it went.
  4. The Following User Says Thank You to koira For This Useful Post:
    macinek102 (24th October, 2023)
    macinek102's Avatar
    Feb 2019
    PL
    I already did it, but thanks
    Do I need to reset the settings in your file and disconnect ADBLUE?
    You got it already working? Disconnect adblue tank if you still have fault reporting on cluster.
    macinek102's Avatar
    Feb 2019
    PL
    I received another file the day before in which I had to disconnect the ADBLUE pump. I asked if the pump also needs to be disconnected in your file.
