Results 1 to 3 of 3
    May 2020
    Default Opel Astra J CD300 20984175
    Hi all,
    After battery replacement, radio not works.
    On bench, I supplied radio and consumtion is about 200mA.
    In car, with diagnostic tool, has 34 errors but not clear and sometimes not does diagnostic.
    Someone can check if EEPROM is ok about VIN and CRC?
    EEPROM 24C128.
    VIN: W0LPD6EA0BG080139
    Thank you a lot.
    WALES
    Quote Originally Posted by electro10 View Post
    Hi all,
    EEPROM 24C128.
    Thank you a lot.
    It's ok with correct CRC
    wbr
  3. The Following 4 Users Say Thank You to shooting For This Useful Post:
    Albert G (24th October, 2023), Decode Ghost (24th October, 2023), electro10 (24th October, 2023), murat332 (24th October, 2023)
    May 2020
    Quote Originally Posted by shooting View Post
    wbr
    Ok, thanks.
    And you know what can be? I read some people with this problem, after battery replacement, radio is dead.
    Can be flash dump corrupted?
    In past, i had a situation with Opel Astra J but about instrument cluster: EEPROM damaged after battery replacement.
    Thank you.
