Results 1 to 8 of 8
    Sep 2016
    Default Honda CR-V 2022 odometer change
    Hello team,A friend wanted the mileage of his Honda CR-V changed from 16533km to 8533kmIc type 93C86I read and saved old ic with minipro, I manually changed the mileage bits with no success (no mileage appears) , from experience bad file could cause that, I loaded back old file and realized my file for some reason might be corrupt as well, to confirm that I took some files from this platform and when I load the mileages appear only that the fuel gauge does not work as well, also a symptom of mismatched hardware.Anyone able to repair my file for me with the new mileage (8533km).Thank you.Sent from my Infinix X6835B using Tapatalk
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    right, your file was read as 93c86 x 8 bits instead of x16 bits, if you put this file in dash, it will not work correctly
  3. The Following User Says Thank You to jomberykaso For This Useful Post:
    keycutters (31st October, 2023)
    clusters's Avatar
    Mar 2015
    Canada
    File is not repairable, you need a new proper dump or a new dash.
  5. The Following User Says Thank You to clusters For This Useful Post:
  6. #4
    Sep 2016
    Thank all you guys,
    Lesson learnt, no more reading such in 8bit,
    Thanks again.
    But can someone offer me a file to correct my ignorant mistake?
    Thanks again
    clusters's Avatar
    Mar 2015
    Canada
    You will have to search the forum for one. If none is found you will have to look elsewhere.
    Dash part number and other info from the label?
  8. The Following User Says Thank You to clusters For This Useful Post:
  9. #6
    Sep 2013
    Try this file and report
  10. The Following User Says Thank You to jomberykaso For This Useful Post:
  11. #7
    Sep 2016
    Thanks, will try and get back to you shortly when I get to shop.
    Thanks again
  12. #8
    Sep 2016
    Hello Jomberykaso,
    Thanks for your assistance, the customer (friend) came back after a long while and your file did the trick.
    Thanks again
