hello, to all members.
Finally, I will open my own locksmith business.
I have bought some second-hand manual key cutting machines from a locksmith who retired recently and I am looking buying an electronic cutting machine for cutting mostly car keys for AKL situations and if it is possible household keys also.
I am looking spending around 3.500 euros for an electronic key cutting machine.
So, cutting machines as futura pro unlimited, ninja total and miracle A9E I know they are good machines but I cannot afford them right now and also, they have very expensive clamps.
I had experience with CG Godzilla machine which I didn’t like at all.
Xhorse Dolphin machines seems to be most popular, a friend of mine has the dolphin xp005 and another the dolphin II.
Dolphin xp005 I consider it old as Dolphin II is now the current model and I am afraid maybe they will stop updates.
As for dolphin II, I borrow it from a friend for a job I had on 6 Mercedes spinter add key situation and the 3 first cars I did decode and then cut and it cut the key terrible it turned but it had cut it shallow, the other 3 car I cut by universal key copy and the keys worked like it should. I know about the hu64 keys types and this wasn’t the case of wrong hu64 key) this machine left me with a bitter taste.
The xhorse condor II I saw it few days before in a locksmith convention and I looked the menu of it and see that in household keys had very small number of key cards (mostly in Chinese letters which I didn’t understand at all (although the language was in English)), almost nothing. The dealer who had it there told me that he wasn’t suggest it for household keys and I better of buy the dolphin 1 or 2 and keep my money.
As for the making the key card on my own form scratch, I don’t have problem as I have made plenty of key cards in the past for silca cutting machines (code maker) but I don’t know if this function works on condor machines. (In CG Godzilla had problem with base cut settings and I contact the Godzilla engineers and they didn’t fix it).
(As far as I know all dolphins have anti backlash lead screw and condors have ball screw which make them more reliable and for long livability and repeatability)
Also, I would like to ask if someone knows if condor II can connect with instacode and cut keys from there (in the instacode site in the compare menu lists Xhorse Condor XC-Mini as instacode compatible machine but I don’t know if the later model (condor II is compatible too).
I also saw the kukai Alpha pro (in U.S. I believe they sell it as triton plus).
This machine doesn’t have a battery which I don’t care as I will run from car with inverter power supply (I think it comes standard with car lighter inverter power supply).
I saw its menu and it seems very good written. in the menu has key card creation tool (if it works) and it can cut household keys too.
Somewhere I read that it is driven by ball screw axles which is better that anti-backlash lead screw if someone can confirm it.
I would like to ask if someone has it and what’s his/her experience with this machine, what he/she didn’t like etc.
Another key cutting machine I consider is the keyline messenger, I talked to the dealer in my country (it is in the very limit of my money spending capability’s.)
It is very light and comes with anti-backlash lead screw it can be powered by 36volts bosch battery and a Bosch charger (the battery doesn’t charge in the cutting machine, need to be removed and placed in the Bosch charger (battery and charger not included in the base kit)
When on battery the main cutting motor turns 7500 rpm and on wall plug 10.000 rpm.
I asked the dealer to see the menu and he showed me a glimpse of 30 sec at most the menu from his mobile phone and told me that it uses the instacode database. I don’t know if it has code maker or if it can connect with instacode program. i don't know if it does what it says it does Also, the extra clamps seemed to be very expensive.
Has anyone had this machine to share his experience?
And finally, if someone does suggest another electronic cutting machine or has an advice, I would appreciate it.
Sorry for the very long post and thank you in advance.
