My thanks for the topic created, it will be of great importance. I have this problem with the 48v 4N0 915 105B Audi Q8 P0A7D00 AND P0B2900 battery. Is there a solution for bench charging the cells individually? Thank you very much in advance
useful info
https://www.youtube.com/watch?v=Yynukw4NxH8
https://www.youtube.com/watch?v=fZVQU7wbdaQ
boost turbo (21st November, 2023), Silegav76 (24th April, 2024), wti (18th November, 2023)
Hello friend, I am carrying out this procedure on the vehicle with the gauges open, releasing the 48 volt positive opening. If you know of a countertop solution, please share, I will do the same. thanks.
You can charge and balance cells if you are know what you are doing, then the errors you can delete. You have to know how to behave with litium cells. If you dont know anything in electronics i recomend give this to electronic technics
I KNOW WELL ABOUT ELECTRONICS, BUT UNFORTUNATELY NOT YET ABOUT LITHIUM BATTERIES. I DID THE PROCEDURE IN THE CAR WITH ODIS BUT I WAS NOT ABLE TO CHARGE IT. I WILL DEEPER INTO THE SUBJECT. FINDING SOMETHING TO SHARE WITH EVERYONE.
Use charger for litium cells, all of them should be charge equal, disconnect wires from central electronic and check all connections from 2 plugs to cells before you start charge and balance them.
wti (29th November, 2023)
First of all you must check the internal resistance of all cells.
Take the cover off and post hi def pics of the inside also post pics of the connector showing the pins
Impactops
HELLO FRIENDS, I DON'T HAVE THE CAR UNDER REPAIR, I HAD TO RELEASE IT DUE TO LACK OF RESOURCES. I BELIEVE THAT ACCOUNTANTS NORMALIZE IF THEY MAKE A LOAD ON THE BENCH. THANK YOU ALL AND SEE YOU SOON
