Results 1 to 12 of 12
    Default How to run Autocom on 21H2 and 22H2
    Hello here is easy guide how to run it on updated win 10 and 11
    uninstall update KB5011048 then use microsoft tool called “Show or hide updates” and block this update
    autocom not working bcs needed old version of microsoft net framework not bcs 22h2 and 21h2
  2. The Following User Says Thank You to veisen For This Useful Post:
    dik (4th December, 2023)
  3. #2
    Aug 2020
    It only works if you have this update! It is not possible to remove, if it is part of the OS! You need to reinstall 22h1. There is no other way around it and we will not remake the 2020 so it does work.
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
    This is always as update …… it can be uninstalled on fresh new 22h2 instalation
    and its milion ways how to bypass net 4.8
    Aug 2020
    No it isnt.
    doesn't mean that if you don't know how that it can't to be done
    Aug 2020
    Quote Originally Posted by veisen View Post
    If you have .net 4.8.1 and you do not have KB5011048 then it CANNOT be done. There is no way you can downgrade .net if it is part of the OS!
    Download a fresh copy of 22h2 or 23h2 and see how much you waste your time
    Dec 2014
    PL
    I have OS WIN 10 Pro 22H2. In my case AC 2020.23 works.
    The system does not automatically download KB xxxx048 update.
  9. The Following 2 Users Say Thank You to Mario6 For This Useful Post:
    dik (4th December, 2023), Lou2007 (6th December, 2023)
  10. #8
    DK Veteran dik's Avatar
    Apr 2009
    In a mental institution
    This should permanently block the net framework 4.8.1 update
    https://support.microsoft.com/en-us/...6-684bce08b77b
    another happy customer
    Sent from my keyboard using fingers to type
  11. The Following User Says Thank You to dik For This Useful Post:
    Mario6 (4th December, 2023)
  12. #9
    Aug 2024
    Porto - Portugal
    There is any solution without reinstalling windows?
    wusa /uninstall /kb:5011048 not work.
  13. #10
    Jul 2023
    hello,
    i try now few days to start autocom but without success
    i have install many times the version 2021 an di know how to do it
    defender off
    firewall off before install
    i have install but software dont start
    i have try from folder to start main.exe
    and i have found something if you start program not open but you have in processes the main.exe
    i dont have it
    what can be problem anybody experience with this
  14. #11
    Aug 2020
    Quote Originally Posted by stipehr View Post
    hello,
    defender off
    i dont have it
    reinstall windows
  15. #12
    Jul 2023
    on the laptop was win 11 i have install win 10 and have work for few days without problem
    and then not work cannot open
    i have then make all the same again but dont start
    i have found on internet few versions what i have download and try
    i have try from CD
    and all the same cannot start
