Page 1 of 9 123456 ... LastLast
Results 1 to 15 of 129
    Aug 2023
    Post NEW WinOLS 4.7 CRACK 2023 / NO-VM / BUGS FIXED / FINALLY VIRUS-FREE
    New 2023 improved crack for WinOLS 4.7
    This crack differs from other for the following reasons:
    - No more "Starting update..." bug!
    - No more changing windows's time / requiring a VM!
    - No more blocking every request to evc.de!
    - Unlike every single public one, NO MORE VIRUS
    - You can now finally browse the internet while having WinOLS open!
    Installation:
    1. Install WinOLS 4.7 (WinOLS4.7.4 - Native Installer.exe), then during the installation, make sure you UNTICK "Create a desktop shortcut", and at the very end untick "Launch WinOLS" !!!
    2. Go to "C:\Program Files (x86)\EVC" and delete the "WinOLS" folder.
    4. Slide the WinOLS directory from the this archive into "C:\Program Files (x86)\EVC" (IF WinOLS ALREADY EXISTS THERE, DELETE IT!!)
    4. Right click the .exe file "C:\Program Files (x86)\EVC\WinOLS\OLS3.exe", go to Properties, go to Compatibility, and enable "Run this program as an administrator".
    5. You can now send a shortcut of OLS3.exe anywhere on your computer to easily start WinOLS
    6. Install WinOLS 5 test version (WinOLS_Testversion.64Bit.exe) normally
    7. Launch WinOLS 5 test version
    8. Click "Choose different path..." and select the directory "C:/Users/Public/Evc/WinOLS" as shown
    FINISHED! YOU CAN NOW USE WINOLS 5 AND THE CRACK!
    Unfortunately, this crack still has a few bugs, including:
    - The auto-scroll, which is easy to stop
    - The ALT + CONTROL not working properly (seeing maps directly in HexDump)
    - Project creation is impossible with the crack (but easy on WINOLS 5)
    The solution to all these problems is WINOLS 5!
    The best use of this crack is by combining the latest WinOLS 5 and this crack! FOR FREE!
    To create a new project, discover maps, and make modifications, use WinOLS 5 because it is very smooth, practical, and visually pleasing!
    Once your mapping is finished, close the project on WINOLS 5 (otherwise it will be locked), go to WinOLS 4.7 to make the checksum corrections and export the .bin! Or use the plugins (for example, the DAMOS IMPORT).
    WinOLS 5 runs without BUGS! So I highly recommend using it to discover maps, navigate in HexDump, etc...
    Be careful, only one instance of WinOLS can use a project simultaneously, so to switch between WinOLS 5 and WinOLS 4.7 on a single project, make sure to close it before opening it in the other version
    Please, note that to create a new project and import a binary file, you have to do the following:
    1. Launch WinOLS5 Test Version and create a new project and import your file and everything as you want to then close WinOLS 5.
    2. Launch WinOLS 4.7 crack, click Open, and the project should be there.
    And if you want to search for maps using the hex dump, and alt left click, do it directly in WinOLS5 !!
    /!\ MAKE SURE YOU LAUNCH THE CRACK AS ADMINISTRATOR!!!
    Obviously, if you do not install according to the above instruction lists, the crack will NOT WORK.
    Credits go to: t.me/Gaztoof
    Feel free to donate to motivate me to crack more software:
    BTC: bc1q6zd8m662vvtrmuk8cmgctl7f7nzcqajs2sh0yv
    ETH: 0x65c93c24d47dF946997b29508D58fb7AF622E500
    BCH: qpspqu33hjt47ppwdxa04gzrgfjn78qnv5h4zpwhld
    If you have a recent version of WinOLS, please contact me so I can try to crack it without leaving your customer id's in the crack!
    DOWNLOAD LINKS ARE ATTACHED TO THIS THREAD
    Also, please note the correct link is the gofile one. You can ignore the other one as he expired.
    Last edited by Gaztoof; 12th June, 2024 at 12:10 AM. Reason: LINK UPDATE because taken down
  2. The Following 370 Users Say Thank You to Gaztoof For This Useful Post:
    007bader (12th December, 2023), 076458C (8th May, 2024), 1971 (18th January, 2024), aaltraz (6th March, 2025), aaronprg (2nd July, 2024), abcde12345 (12th December, 2024), abdge2546 (29th March, 2025), abdonete (27th October, 2024), acamip (22nd July, 2024), accodinguk (27th May, 2024), ADEL.KSHLAF (9th September, 2024), adelbenterki1 (10th January, 2025), Adrian18d (24th November, 2024), Aleks1975S (12th April, 2024), alfiones (2nd March, 2025), aliel (27th October, 2024), amaiod amaiod (18th April, 2025), ampirnn (8th October, 2024), Anaboltoni (28th December, 2024), Anakinsw (9th November, 2024), Anissem78 (21st August, 2024), ant21000 (12th December, 2024), antonypaul (4th January, 2025), Anydraj (10th February, 2025), aqwxszz (17th August, 2024), armin0676 (1st July, 2024), artur4o (2nd February, 2025), asdaly (29th January, 2025), ashjms (30th November, 2024), assulya1 (3rd June, 2024), atomantmk (12th December, 2024), autobuggy (27th October, 2024), AvusKonie (24th November, 2024), ayllon308 (5th October, 2024), azzlck187 (18th November, 2024), barteeeek (15th February, 2025), Bartex (20th November, 2024), Bauer77 (29th March, 2024), baurivera (26th November, 2023), bboctavian (27th November, 2023), beltronics (15th January, 2025), bgd_ct (14th July, 2024), bibass (4th December, 2023), Biotoxic (3rd November, 2024), biscoitoms (8th February, 2024), Blackcat96 (16th March, 2025), blackground (26th January, 2025), Blackrain31 (25th January, 2025), Bloo (18th September, 2024), bokilee (9th April, 2025), bondsbulli (30th August, 2024), boxsport (4th March, 2024), brave (7th November, 2024), breez (18th April, 2025), Bremond (11th December, 2024), bugmeister (28th February, 2025), bullseyemods (26th August, 2024), bunda (4th December, 2023), burovvadim (21st September, 2024), bysamir (15th September, 2024), CABLEMAX (15th September, 2024), CakeBleu (25th November, 2023), canon (21st April, 2025), capma (11th February, 2025), ChappyK (5th January, 2024), chrisi15 (31st March, 2024), CHRISOCCO57 (10th May, 2024), ChrisVonHertz (14th April, 2025), cichy616 (14th February, 2025), cicko (20th January, 2024), Clueless17 (24th November, 2024), cojida (2nd December, 2024), Connah (15th April, 2025), corsair303 (19th October, 2024), Costa014 (29th November, 2024), Crazy18T (30th November, 2023), crazywolf79 (28th January, 2024), daniersms (13th December, 2023), dannygi (17th August, 2024), danybix (30th March, 2025), darrynf (6th March, 2024), dasa007 (1st April, 2025), dasbo1 (23rd December, 2024), davidbcn (29th February, 2024), Davimk2 (23rd June, 2024), dawco998 (23rd November, 2023), deezigna (21st July, 2024), dejan05 (25th November, 2023), deksioo (25th February, 2024), diabolik2 (4th December, 2024), diblos (10th June, 2024), DieCor (24th September, 2024), dilock (12th March, 2025), Domi (12th December, 2023), dragonbomb2k20 (31st December, 2024), drcoding (4th September, 2024), DylanJP1234 (26th January, 2025), Dyneteve (10th January, 2025), dzban (7th July, 2024), E90BMW200hp420n (21st November, 2024), ecufix (5th December, 2023), ecustand (14th January, 2025), edogawa (17th November, 2024), electromech (3rd June, 2024), emibmwe47 (27th December, 2023), emptyhb (25th September, 2024), enok542 (23rd July, 2024), entrika888 (29th October, 2024), EnzothedarkPT (14th October, 2024), eoos (27th October, 2024), estica71 (27th January, 2024), Ezalevi (26th November, 2023), Ezziox05 (27th October, 2024), famaouscrystal (28th February, 2024), FatihC (13th July, 2024), felix297 (21st April, 2024), fetyboy (28th January, 2025), fjc (26th August, 2024), formulecu (22nd December, 2024), Fuscus (27th November, 2024), FuzionH (11th January, 2024), gabynox78 (22nd September, 2024), galiza (12th December, 2023), Gebalana ARJ (13th June, 2024), genadko (9th October, 2024), gerotgm (26th December, 2024), Gery (14th January, 2024), GH05T (24th February, 2025), gifret (11th December, 2024), gimini87 (25th November, 2024), gmax (19th September, 2024), GNTV (2nd August, 2024), Go3rri (4th November, 2024), GOLDFAIRE77 (2nd October, 2024), guidotacco (30th January, 2025), harko1234 (18th November, 2024), hbalazs (9th December, 2023), Henrike21 (31st October, 2024), hercamp (29th December, 2023), hhp (24th December, 2024), himura (23rd September, 2024), hoangtu (5th December, 2023), horbalazs (2nd March, 2024), hrsuz (26th January, 2025), ibm (14th October, 2024), ignac112 (11th January, 2024), inunxelex (1st April, 2024), Ionutzllz (10th April, 2024), irfas (20th April, 2024), Itagent (24th September, 2024), Iterio (3rd July, 2024), IvanGF14 (6th January, 2025), ivarsdz (10th January, 2025), JacekPlacek (2nd February, 2025), jarog (30th January, 2025), jd466 (25th April, 2024), Jefke77 (9th June, 2024), jejevfr (13th January, 2024), jenny123 (18th January, 2024), jerrygera (28th November, 2023), jlandim (3rd November, 2024), joe06 (27th January, 2025), joejam (21st January, 2024), jogobelo (19th February, 2024), jonnyxd27 (8th February, 2025), jordiksvk (12th December, 2023), JOSARBDS (3rd January, 2024), jpolitanski (21st November, 2024), juane (20th August, 2024), Kao (17th April, 2025), kaosbite (29th November, 2024), karimdz (11th January, 2025), Kasztelan (28th November, 2024), kayags (4th November, 2024), ker0de (9th March, 2024), Kheivvandorn (22nd November, 2023), kissxpchao (9th February, 2025), kitloy (2nd October, 2024), kocamehmet42 (19th March, 2024), Kogen11 (23rd December, 2024), kostadinfix (1st August, 2024), kriminelleente (9th January, 2025), Krisz1111 (7th March, 2024), kubex236 (24th March, 2024), laki23 (12th April, 2024), largosoft (27th November, 2024), Lemazout16 (17th March, 2025), leospank98 (18th December, 2023), leowii (28th November, 2024), lilvirtt (4th March, 2025), LITTLE JOHN (20th March, 2024), Louislesinge (16th March, 2025), LucioTuned1 (4th March, 2025), LukaRant (29th November, 2024), lvortexxx (22nd February, 2025), LyuboDAR (21st March, 2025), lyusi krumov (12th January, 2024), madmick (4th January, 2024), Make80 (30th November, 2023), man (4th July, 2024), marecaimans (8th October, 2024), Max530d (14th August, 2024), mazmanx (15th October, 2024), mecon (28th January, 2025), mekfly (23rd January, 2024), memo13 (14th January, 2025), mertdavid (6th December, 2024), metoo77 (7th March, 2025), mhsl (9th January, 2025), michele74 (25th May, 2024), micsher (17th February, 2025), mikiotty (9th January, 2025), mk5gt (25th August, 2024), mkopytekchi89 (2nd February, 2025), moky (22nd November, 2023), moldo25 (12th February, 2025), monsterislife (1st January, 2024), mototool888 (3rd December, 2024), mouatez32 (10th April, 2024), mrx115 (23rd April, 2025), muchastd (5th March, 2024), mysterious (28th January, 2024), nabilrifi (23rd November, 2023), namerows (29th October, 2024), nik65 (9th March, 2024), nobby1967 (29th January, 2024), obbyforce (13th April, 2025), oldnavys (16th June, 2024), ombre57 (23rd November, 2023), osipsa (2nd April, 2024), Osvaldo (12th August, 2024), Outlaw666 (18th July, 2024), Pandas64 (24th February, 2024), PaoloDigital (26th December, 2023), Patto (22nd November, 2024), paulo23pacheco (7th September, 2024), PeetrsCerny (30th November, 2024), pilegspeed62 (3rd March, 2025), pjfian (15th November, 2024), PJocc (31st July, 2024), pmmatty (13th December, 2023), poolli (8th January, 2024), ptdborth (22nd November, 2023), Pupa1986 (17th April, 2025), pvkosherov (23rd November, 2023), quato79 (10th January, 2025), Radon (2nd August, 2024), ricardoadami (19th January, 2024), rimer (30th May, 2024), Romeo26222 (27th October, 2024), roop (1st December, 2024), rossitec (7th April, 2025), royarnouts (16th November, 2024), rreynolds (3rd January, 2025), rybenz (4th January, 2024), sanscorp (15th April, 2025), Sanyo320 (8th February, 2025), Sendan (12th December, 2024), Silegav76 (22nd December, 2024), Simi123 (10th December, 2024), Slav1984 (29th December, 2024), smtmrc (10th April, 2024), souljahhhh (17th January, 2024), SSK2012 (31st March, 2024), stanislav georgiev (6th April, 2025), statistic (3rd March, 2025), stemc (5th January, 2025), stevan (29th March, 2025), StevenW (19th September, 2024), Strepchyy (21st April, 2025), Sunaifmj (2nd July, 2024), Synaro (21st August, 2024), thejurysout (13th January, 2025), thenewon (14th October, 2024), thofth (15th December, 2023), tonydxb (7th February, 2025), totorsss (20th August, 2024), tsnami (25th February, 2024), TurbaX (30th January, 2025), upvsamsung (18th September, 2024), urbandamage (3rd April, 2025), uricom37 (7th March, 2025), vanos batam (12th January, 2024), vectrac20tsri (13th July, 2024), vervoort (26th March, 2025), vespet82 (20th January, 2024), vladim1 (14th August, 2024), voemiw (17th February, 2025), volodin69 (7th July, 2024), Vuk447 (10th January, 2025), Wameed (15th January, 2024), wayne9876 (12th December, 2023), werner1337 (23rd November, 2023), WivernX (15th January, 2025), Wolfpack (25th November, 2023), yandeec (30th July, 2024), Yuri_L777 (16th October, 2024), Zaiimon123 (9th December, 2024), Zaur2323 (25th October, 2024), zombiforum (24th December, 2024), ZondaHivic (8th August, 2024), zsolt162 (5th May, 2024), zweb007 (6th December, 2023), zyjekrc51 (15th December, 2024)
  3. #2
    Klaudas1331's Avatar
    Dec 2020
    Lithuania, Kaunas
    Cannot load library WDAPI1200.dll, got this error, did everything like instuctions said, Win10
    Custom tuning services and solutions for VAG/BMW Diesel cars.
    If my post was helpful, don't forget to press thanks!
  4. The Following 6 Users Say Thank You to Klaudas1331 For This Useful Post:
    man (20th July, 2024), moleo (13th April, 2024), nik65 (9th March, 2024), Rivalzn (9th June, 2024), walid77 (8th June, 2024)
  5. #3
    Aug 2023
    Germany
    Quote Originally Posted by Klaudas1331 View Post
    It is working fine for me, do you need Help installing it?
    Using Flex, Kess, Ktag and Mpps
  6. #4
    Aug 2023
    Inside the WinOLS folder, there's a vc_redist.x86.exe, try executing it, might fix your problem.
    If this doesn't fix it, browse to WinOLS/driver/32on64, the WDAPI1200.dll should be in this folder, COPY it over to WinOLS/ (next to OLS3.exe)
  7. The Following User Says Thank You to Gaztoof For This Useful Post:
  8. #5
    moky's Avatar
    Behind you
    here ask update no work windows 11 install same as you ask
    EngineGen is a robber : Dmitry Tolmachev !!!!! Be careful guys !!! this guy sucked me 180 euros ....
  9. #6
    Nov 2023
    Cambodia
    Not version English sir
  10. #7
    Apr 2019
    For me it does not work. Even after messing with conf of language and setting to German it still wont launch and drops no error.
  11. #8
    Aug 2023
    If you have problems it's probably because you have the old crack left. Totally delete the old WinOLS folder and slide the new one instead, and then execute the rest of the instructions.
  12. #9
    Jun 2020
    Everything went well, but when i want to add file it pops update+registration windows and cant go further
  13. #10
    Aug 2023
    Quote Originally Posted by dawco998 View Post
    Thanks for posting that out, will update the thread in a few mins with a fix for that
  14. The Following User Says Thank You to Gaztoof For This Useful Post:
  15. #11
    Jun 2020
    So basically you say everytime you want to import project you must do it by Demo and then use crack?
  16. The Following User Says Thank You to dawco998 For This Useful Post:
    ZondaHivic (3rd December, 2024)
  17. #12
    Jan 2021
    Germany
    Thank you for the upload. It's working well so far. Sometimes the scrolling bug appears, which is fixable by resizing the Hexdump window.
  18. The Following User Says Thank You to werner1337 For This Useful Post:
    Gaztoof (24th November, 2023)
  19. #13
    Mar 2017
    Portugal
  20. #14
    Aug 2023
    Yep, exactly
    Quote Originally Posted by marko6jpt View Post
    Personally I do not have this problem, you're most likely using the old crack version or something, please totally delete the EVC/WinOLS directory and reinstall ACCORDING TO THE INSTRUCTIONS LIST, might fix your problem!
  21. #15
    Aug 2023
    Also, this is a message to everyone;
    I'm thinking about making a windows app with a server where you can upload your Damos files, original maps, and map packs for every ECU type, and so you can also download the maps and damos that are already on the server, which would be way more organized than posting on forums and would benefit EVERYONE!
    Please, leave a thanks or a reply to this post if you would use it and would be willing to upload the data you have to it.
  22. The Following 35 Users Say Thank You to Gaztoof For This Useful Post:
    2chabz (21st March, 2025), aaronprg (27th June, 2024), Aleks96 (25th October, 2024), Blackcat96 (16th March, 2025), brave (7th November, 2024), cicko (20th January, 2024), corsair303 (19th October, 2024), Crazy18T (30th November, 2023), d3xter991 (7th January, 2025), deliaga (12th December, 2023), eddieddi (20th November, 2024), Engin3169 (25th November, 2024), fifii69 (1st December, 2024), Glennd789 (10th March, 2024), hercamp (1st December, 2024), iLLogicaL (11th January, 2024), IvanGF14 (6th January, 2025), jejevfr (13th January, 2024), KK1028438062 (19th December, 2024), kocamehmet42 (19th March, 2024), kwat (16th January, 2024), laki23 (2nd January, 2025), lz1gad (20th January, 2024), mandzo (1st April, 2025), rayssant (3rd December, 2023), ricardoadami (19th January, 2024), ronaldoveloso (11th June, 2024), serviclau (10th February, 2025), tuningfiles (25th May, 2024), upvsamsung (18th September, 2024), Vuk447 (10th January, 2025), werner1337 (26th November, 2023), zsolt162 (5th May, 2024)
