I am having this output on the serial console:
*** could not load FPGA image @40000: DONE pin low after programming
*** could not load FPGA image @100000: DONE pin low after programming
IPL: BMW L6 B001 / QNX 6.3.0 [PL_qnx_ipl-l6_B001_08253A, built 2008/06/18_15-20-24_UTC]
CPU: SH7785 (>= 5th cut, clk mode 16, 4xDDR), 594MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
*** NO FPGA loaded!
Entering CLI, type '?' or 'help' for help
A scan command reveals the images:
** @0x80040000: FPGA
total size: 746480 [0x0b63f0]
data: 746212 [0x0b62e4]
.FDR = PL_BMW_L6_CIC_7534_FPGA_D_10504A
.FDU = User-Info for FPGA 7534_D_4020_10GV
** @0x80100000: FPGA
** @0x80280000: IFS [vers.1, LZO, APPLICATION]
total size: 4864260 [0x4a3904]
- header: 256
- startup: 53512
- imagefs: 10923608
RAM: 10977120 [0xa77f60]
** @0x86dc0000: IFS [vers.1, LZO, EMERGENCY]
total size: 5151884 [0x4e9c8c]
- header: 256
- startup: 53512
- imagefs: 10724764
RAM: 10778276 [0xa476a4]
** @0x87f80000: BIOS packet
total size: 524288 [0x080000]
BIOS pattern: FFFFFFFF.FFFFFFFF
App. pattern: FFFFFFFF.FFFFFFFF
What can be the reason why DONE pin is seen as LOW. Hardware issue? Programming issue. Configuration?
Thank you in advance for your hints.
