Results 1 to 4 of 4
    Mar 2022
    DE
    Default Clone Ford EEC-V
    Hi All,
    I need to clone a Ford EEC-V, model 4S7A-12a650-GB from a Mondeo V6 which has a water damage.
    I can obtain a ecu with same number but I'm unsure how to clone the Data.
    ECU has a 8Pin SOIC ST IC labelled 9405K which I assume is the EEprom.
    Can I read & write ECU with PCMFlash and copy EEprom manually on bench?
    Mar 2022
    DE
    Anybody able to help here, please?
    dimitar's Avatar
    Just use forscan and adapt the new ecu ....you need 2 keys....5 min job
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Jun 2013
    EU
    Try copying 95040 eeprom from ori to donor, you have nothing to loose. Just remember to keep spare ecu original eeprom dump just in case you need to go @dimitar suggested way. Copy the 95040 is really fast and normally gives the desired results.
