Results 1 to 13 of 13
    spiridonas's Avatar
    Default OPEL OP-COM PLEASE HELP
    Hi i have a astra h and instal a cd30 mp3 clear ready to program .I tried to programming with op-com latest version but nothing i have car pass, key code and radio code. Please help me how to programming radio with op-com
    every 5 sec says message radio program and beep.
    Many thanks in advance spiros
    Quote Originally Posted by spiridonas View Post
    Try this :
    Ignition on, Infotaintment system - EHU, go to mid bus configuration, enable EHU and enable GID
    Infotaintment system - GID, mid bus, enable EHU - GID
    Return to infotain - EHU, insert your code, wait for ok, then exit men?, ignition off for some second and try if it works.
    What opcom are you using ?
    i've a problem with OPCOM090820d_EN, similar to your, but with BCM code, solved using an older version...
    Jun 2009
    not yet discovered solution to these radio cd 30 I had to dump some but it was kicked or if there is a solution for cd 30 for this please let writes for a message thanks
    Quote Originally Posted by Dragi View Post
    spiridonas has a clear cd30mp3.
    also my cd30mp3 is blocked 'cause a bad unpairing from original car, i payd 80 euro 2year ago for this radio
    Ok this explains how to marry using opcom but how do we divorce?
    Quote Originally Posted by donovan2123 View Post
    If i remember, under GID-BID-CID there is a voice called disable anti theft mode, and there is the same voice under EHU.
    Go to the two disable, enter your code, and i think they're divorced !
    If you can't find the disable anti theft, try astra H, then infotaintment, ecc ecc
    I have tryed this method to marry a cd30mp3 but i cant seem to get it to work i can find the one option to deactive the theft but it wont do it. It comes with failed. Will allow me to activate it though but this doesnt solve my problem
    Any ideas?
    Are you sure is the correct code ? Tried to deactivate both GID and CD30 ? Check also if EHU or GID are set to "Present"
    Yes 100% code is correct as it was used to divorce old stereo. Just need to marry now to stop anoying beep.I have checked both are set to present and deactivate only exists in EHU and not Gid. My code is accepted to activate but this does not seem to marry as still have beep.
    MONTPELLIER-FRANCE
    Default programm ehu
    What is the message on your dis? if it is "radio safe" and "display safe", you failed marrying EHU but if it is "programm radio", you need to programm code index and audio index
    i have the same issue on my cd30 mp3 and is normally divorced from the old cars
  13. #13
    Default programm radio
    Quote Originally Posted by seb34 View Post
    I have the same problem as spiridonas. Corsa c, 2006y. Virginized radio via dump, have car pass and pin code. Tried with opcom 090820d and no success. With older it accept pin but does not have support for module TID-GID or whatever... It says: the file cannot be loaded: HASTRAEHU_GEN.MBF. Is it possible SOMEHOW to adapt radio with opcom???
    Tnx!!!
