Opel Delco E98
BENCH - Does not work. It reads the ID fine with all SW numbers but cannot read it.
BOOT - Does not work. After read error it asks for password (OK that could be normal but there is no option to read the password in Bench or OBD - so useless..) And after you cancel that operation Multi Prog device hangs up and only way is to restart it with power switch.
Also for some ECU's the Pinout information is confusing that could lead to burned HW (ECU/TCU or Multi Prog) where pinout picture is correct but top right pinout legend is numbered wrong.
Also there are a lot of ECU's listed where inside memories are shown 0 and is not working.
For example take Scania EMS S8 ECU
Only option is BOOT. Pinout for external connector is correct but there is no information about actual BOOT connection on PCB where 3 wires should be connected near MCU.
They are advertising this as ECU/TCU read/write/clone tool but it is very half-baked product at the moment.
