Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 92
    Maartinj's Avatar
    Nov 2010
    Default .>>>>>>>>>>>>>>>>>>Xhorse Multi Prog<<<<<<<<<<<<<<<<<<<
    New Xhorse Multi Prog device
    Let start discussion here and only here
    >>>Download software<<<
  2. The Following 5 Users Say Thank You to Maartinj For This Useful Post:
    mikajna (9th December, 2023), Papiti56 (28th May, 2024), sniegavirs (29th December, 2023), Tachodiag (8th December, 2023), ttzag (13th December, 2023)
  3. #2
    foxtec800's Avatar
    No information on this with regards current VVDI-prog functions, is it only ecu/tcu cover on release and are eeprom/mcu being added or left
    on vvdi prog ?
    ttzag's Avatar
    digital-kaos
    Is it fully instead of vvdi prog?
    Or we need to use both?
    Actions speak louder than words
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by ttzag View Post
    Right now , there is no adapter for old adaptors such as XDPG14 - they use IDC connector
    so they can not be mount in Moultiprog
    Nov 2023
    Can Support NXP NCF29xx:
    NCF2951(24K)@TSS0P38
    NCF2951@ICPLine
    NCF2951@TSS0P38
    NCF2951ETT@ICPLine
    NCF2951ETT@TSSOP38
    ECF2952@ICPLine
    NCF2952@TSS0P38
    NCF2952ETT@ICPLine
    NCF2952ETT@TSS0P38
    NCF29A1(24K)@ICPLine
    NCF29A1(24K)@QFN32
    NCF29A1@ICPLine
    NCF29A1@QFN32
    NCF29A2@ICPLine
    NCF29A2@QFN32
    NCF29A3@ICPLine
    NCF29A3@QFN32
    NCF29A4@ICPLine
    NCF29A4@QFN32
    brend's Avatar
    Oct 2015
    Same where
    Spansion still no in here !
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Looks promising. Finally usable HEX editor only missing function is ability to switch from HEX to Decimal view. That would be very useful!!!
    Jan 2017
    Looks good, what to come of the old faithful vvdi prog? have instabilities of vvdi prog been addressed? mcus which had issues being read/cracked?
    A little late to the market with what it is offering in terms of the ecu/tcu functions, nothing new to make it stand out or make it a must purchase for everyone. Most advanced comrades will have tools which cover them, suppose its a good starting tool for the new comers...
  10. #9
    sniegavirs's Avatar
    Mar 2017
    Latvia
    This thread should be transfered under --> Airbag, ChipTuning, Dash, ECU, IMMO, Locksmith, Radio, SatNav section in forum. Here it is unnoticed.
    It looks like there are problems with Multiprog and also Key Tool and Mini Prog using soderless adapters for CAS4 and Land Rover KVM
    https://www.youtube.com/watch?v=e4tmAsr3Fxs
    "VVDI MULTIPROG, KEY TOOL PLUS, VVDI MINI PROG failed to decode CAS4+ (5M48H) with Solderless Adapter.
    in the beginning, when the solder-less adapters first came out the algorithm used to decode, the BMW Cas4/4+ module used to work perfectly. until recently, Xhorse decided to update the algorithm to decode/crack cas 4+ .
    nothing will work not the key tool plus, VVDI, mini Prog or Multiprog because they all used the same algorithm since they’re part of the same system.
    VVDI Prog the Original Tool is very different in terms of reading chips and decoding, certain MCU that are not found on the key tool plus or multi prog.
    xhorse please fix the problem. This cannot be ignored
    ADAPTERS THAT CURRENTLY DO NOT WORK ON MULTI-PROG:
    1. XDNP12 - CAS4/4+
    2. XDNP16 - LAND ROVER/JAGUAR KVM"
  11. The Following User Says Thank You to sniegavirs For This Useful Post:
    mikajna (9th February, 2024)
  12. #10
    badenaleks's Avatar
    Feb 2012
    Windy City
    Hi everybody! Maybe somebody tried to add his script to Multiprog? I am asking because it looks like we have this option but a manual on how to add your script in Chinese.
    Everything will be okay!
  13. #11
    mikajna's Avatar
    Mar 2015
    Hi guys I just tested on two ecu, didnt test anything else
    Edc17c46 Vw golf 6 Read eeprom and flash on bech
    Its ecu from my stock and dont know if everything went good, but reading success
    Edc16c34 Peugeot failed to connect, tested on several ecu from list, and two pinout versions
    Come on guys, share your experince, and we will see is this tool hit or miss
  14. #12
    mikajna's Avatar
    Mar 2015
    Kia Hyundai EDC16C39 bench eeprom/flash read and write - OK
  15. #13
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    msd80 r/w ok
    DSG TUNING
    File Service
  16. #14
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Default VVDI MULTIPROG
    I see that there is no VVDI Multiprog thread.
    Feel free to post feedback here.
    I personally tested on edc17c49 Iveco boot mode: all ok.
  17. The Following 5 Users Say Thank You to lupu_sandu For This Useful Post:
    BadeaCristian (26th February, 2024), bmujka (26th February, 2024), Hayssam1 (30th June, 2024), jarbo3a (11th March, 2024), PremierD (17th March, 2024)
  18. #15
    Aug 2019
    Romania
    it does checksum as well?
    Press Thanks Button and Reput if i helped !
