Results 1 to 15 of 16
    rob h's Avatar
    May 2011
    Default Micra Nissan k12 keyless akl
    Hello guys
    I can not find the stamp on the passenger doorlocks.
    I used a lishi,
    And have 4 options to cut.
    How will i know, if i have the correct cut code?
    Without transponder, learned, will these ignition locks turn on?
    (They told me, it was a regular ignition, so i have to cut the keyhead smaller to fit, for know.
    Have to do this 3 more times, is not what i want to do, )
    The push button, next to the ignition lock, what does it do?
    Dec 2010
    Nottingham
    you can cut any of the 4 options and will work in ignition as ignition doesnt house full set of wafers , often only 1 wafer is present.
    most good programmers will disarm steering lock and allow ign to turn to code transponder , halkyard/truecode or smart pro , need to convert glovebox label to get pin
    ideally you need the blade for the intelligent key .
    the push button is important , not using it can cause key programming to fail , when programmer instructs you to turn off ignition , its not enough to just turn key , you then press this button and key turns a little more , it wont be fully off until you do this , and not being fully off can cause programming to fail
  3. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    rob h (8th December, 2023)
    rob h's Avatar
    May 2011
    Doorlock
    Xxx31224333
    I loaded these in insta, and selected the 11cuts.
    I could only cut 3, out of the 4.
    The door opens.
    But all should work? Okay
    They did not.
    The owner told me, he had to use remote to lock and unlock, at times.
    Before the ignition would turn.
    I have the bcm code and pincode.
    Keyprogramming, it will do,
    Know 0 keys, because i could not turn the ignition.
    I will look in to it.
    Was doubting if i cut the correct key,
    But i have, according to your explanstion.
    Id60 transponders, on a 2004?
    I will check this later,
    Jul 2019
    Melbourne, Australia
    Don't see these keyless Micra that early here, but rapid is correct. On all the twist prox Nissan vehicles that I have seen only 1 wafer is present in the ignition to retain the key in emergency start condition. If it works the door, and turns and retains in the ignition with transponder programmed(must release steering lock electronically to turn ignition and program a transponder and must have a programmed transponder present to learn remote) you are all good. You can also remove the ignition switch and do the transponder programming by turning the ignition switch but I don't recommend that as you're not following the original programming procedure.
  6. The Following User Says Thank You to Spiritech For This Useful Post:
    Mar 2018
    UK
    Quote Originally Posted by rob h View Post
    Doorlock
    Xxx31224333
    The door opens.
    They did not.
    Rob from where you falling mate ???
    why you look for 11 as this car use regular NSN14 on card 220 with 10 wafers
    just cut 1131224333 on card 220
  8. The Following User Says Thank You to Manta1600 For This Useful Post:
  9. #6
    rob h's Avatar
    May 2011
    instacode Micra k12.jpginstacode shows me this.
    That is why.
    I know understand, the key will be fine, as is.
    The elv, is what i need t unlock by diag.
    Perhaps i could use Avdi, to program keys. Nissan key programming is free in Avdi when you have the pin?
    I will check this.
  10. #7
    EU
    I try one few weeks ago with AVDI and failed
    I use old t300 and done new key in 5 minutes
    i think AVDI coludn't unlock elv
  11. The Following User Says Thank You to davorOS For This Useful Post:
    rob h (9th December, 2023)
  12. #8
    Mar 2018
    UK
    That is why.
    I will check this.
    If you use card 840 must put one more 1 - 11131224333
    but I never faced car that use card 840
  13. The Following User Says Thank You to Manta1600 For This Useful Post:
  14. #9
    Dec 2010
    Nottingham
    avdi has always failed on these for me in past , only advanced diagnostics and halkyard/truecode have done these for me .
  15. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  16. #10
    rob h's Avatar
    May 2011
    Steering lock, i can unlock, with the pincode.
    I tried a few transponder , 4d60, 40bit.
    I dont have a 4d60 80 bit option, in xhorse, or keydiy.
    Do i need 80 bit?
    285E2-AX610 version information
  17. #11
    Greece
    Not need 80bit. Normal 4d I'd 60 transponder. But I have succeeded only with MVP .
  18. The Following User Says Thank You to kleidaras For This Useful Post:
    rob h (23rd December, 2023)
  19. #12
    rob h's Avatar
    May 2011
    Ok, i will give that a try, thank you
  20. #13
    May 2020
    If any part of that prone to fail keyless system is not working properly you will have great trouble programming the 4D, I once had to call a friend to add a chip directly to eeprom with TMpro because they are the only ones who developed the propper software for that car...
  21. The Following User Says Thank You to turismou For This Useful Post:
  22. #14
    newone's Avatar
    Oct 2016
    i have done a reykey in one about 2 months ago and had full waffers in ignition lock,ignition never had dissasembly before,always use truecode on these,very fast
  23. The Following User Says Thank You to newone For This Useful Post:
  24. #15
    rob h's Avatar
    May 2011
    Thanks guys,
    Nissan Micra 2005- (iKey) Is covered in Tango.
    i will try this.
