Results 1 to 9 of 9
    Jul 2016
    Default ME7.5 immo off help
    Hi freind's, please i need help to immo off this ecu from a vw beetle; ecu is BOSCH ME7.5 c4 06A 906 032 MQ; eeprom inside is 95040, please can someone help. thank's a lot in advance
    Feb 2018
    Please check your read, there is something wrong.
  3. The Following User Says Thank You to mj12345 For This Useful Post:
    Drdiag (11th December, 2023)
    Jul 2016
    Hi freind. Thanks a lot. My dump is bad ? And i must write your dump now ?
    Feb 2018
    Here is a example from another 95040 1.8T eprom. There is missimg the first bit in your file.
    Jul 2016
    Hi freind's, there is my dump readed with another programmer, can please someone check if this is ok? and make it off, if no, please can someone repair this dump them off to start the car? thank's a lot in advance
    Sep 2018
    Quote Originally Posted by Drdiag View Post
    HI
    TRY this a file
    95040 beetle off.rar
    Press THANKS for pass.
  8. The Following 2 Users Say Thank You to erkor For This Useful Post:
    Drdiag (12th December, 2023), OpelRazvan (15th April, 2025)
  9. #7
    Jul 2016
    i ll and report; tks again
  10. #8
    Feb 2018
    This dump is OK. Here your File.
  11. The Following User Says Thank You to mj12345 For This Useful Post:
    king alie (22nd April, 2025)
  12. #9
    Mar 2025
    Hi with wich program did you remove the immo to that ecu? I tryed swiftec, immo by pass, stage x... etc and I have not solutions. I ll wait your answer, thanks.
