Results 1 to 1 of 1
    Nov 2020
    Alicante, Espaņa
    Default Skoda Octavia II 1Z 2010 - 2013 Dashboard PinOut
    Hello, I have been looking everywhere for the PinOut of this dashboard, and I have not found it. I had to go to the electrical diagram.
    I share it, for whoever needs it. The dashboard only has a 32-pin blue connector. All the best.
    Pin 1: one end of the fuel gauge potentiometer.
    Pin 2: one end of the fuel gauge potentiometer. (The fuel gauge has a resistance of 300 Ohms. It is identical to a potentiometer. It has three terminals, one is the central socket of the potentiometer, and the other two are the ends. The center jack goes to GND).
    Pin 7 and Pin 8: Inmo Coil
    Pin 16: GND
    Pin 20: GND
    Pin 31: Term. 15 ( +12V)
    Pin 32: Term. 30 ( +12V)
    Pin 28: CAN H
    Pin 29: CAN L
    Pin 18: Temp. Gauge (a resistor is placed with one of its terminals to ground)
  2. The Following User Says Thank You to joaquinmjuan For This Useful Post:
    Stelaras26 (7th March, 2024)
