Results 1 to 5 of 5
    Apr 2016
    Default 4H0959655C Airbag module cloning info
    Hi guys!
    I have a delicate situation with this airbag module. Here's the story:
    Original airbag unit had "Replace control unit" DTC
    Got another one, same number but different HW number, did a component protection, everything went fine,but the module doesn't accept coding provided via ODIS online. So i tried to make it virgin and again with AVDI, everything OK... Here comes the moment when I f'd up; i did reflash with corresponding .frf file found on VAG flash disc, everything went fine but in the end it says: flash failed.
    Now I got Airbag module that doesn't communicate with anything in car, but I can connect with it through diagnostic and that's all. No possibility to reflash or virgonise...
    I've played a little with the old module, managed to read NEC processor and found that there are only 00
    (zeroes) i D-flash section and some data in P-Flash.My guess is that D-Flash is empty because unit have external 95XX eeprom.
    Is this enough to clone the unit? I ask because there are two BOSCH chips. Or there is something else that I can do, except getting another unit.
    Thanks!
    fuzz1's Avatar
    Jul 2019
    Post your file read from the eeprom. Hopefully a clear of the eeprom might solve the problem. Return the files you read into the eeprom and mcu
  3. The Following User Says Thank You to fuzz1 For This Useful Post:
    alkaskad (21st December, 2023)
    Apr 2016
    Here are the files from original unit. Eeprom and MCU dumps.
    fuzz1's Avatar
    Jul 2019
    Strange reading from the eeprom. I was expecting to see the vin number there. Is the reading from the second module similar?
    Apr 2016
    I didn't touch "new" unit... I forgot to tell one thing, original unit was water damaged.
    EDIT: Check the file named save20231218_103811_212 ORIGINAL. That's 95640 dump and there is VIN number.
