Results 1 to 5 of 5
    razvanrms's Avatar
    Sep 2015
    romania
    Default Daewoo matiz 2006 immo problem after battery flat
    Hello . I want to repair/resync immo on Daewoo matiz 2006. I read imobox 93c56 file after battery flat .
    With ignition on , security light stay ON , solid red , and with ignition off , security light blinkl.
    I make a new transponder id48 with vvdi2 , same problem
    I relearn all keys with OBDSTAR , same problem
    I put OF68 EMULATOR in ecu , car no start , emulator only power , no sync with ecu , blue LED stay off , i connect with DAEWOO2 diagram from carlabbimo
    P1629 ERROR STORED IN ECU
    if keys in vvdi2 is : key 1 D9B54B8F
    KEY 2 D9B55E4F
    IMMO IS IM730 IMMOBILIZER
    ECU IS D3 1BAN 5U
    THANKS !
    rafal's Avatar
    UK - PL
    if emu not helped - file with off also will not solve your problem
    search problem somewhere else - not immo
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    razvanrms (5th January, 2024)
    razvanrms's Avatar
    Sep 2015
    romania
    Thanks for replay. Ecu deffective ?
    rafal's Avatar
    UK - PL
    Quote Originally Posted by razvanrms View Post
    can be...............................or wires
    need help
    who will help?
  6. The Following User Says Thank You to rafal For This Useful Post:
    hi, did you solved your problem with daewoo matiz???
