Results 1 to 15 of 16
    Oct 2015
    Default vw phaeton unknown version
    vw phaeton from 2004 all key lost. read kessy continental 5wk48508a but unknown version with tango. autel give me all datas and write key in dump but immobiliser active at display and car cant start. can someone check my dumps please? any expierences with this old car?
    vw phaeton unknown version.rar
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
    jodge's Avatar
    Mar 2017
    i have similar problem with A8 (basically the very same kessy) only the AVDI was able to corretly precode the TP and i've tried all of my stuff
  3. The Following 2 Users Say Thank You to jodge For This Useful Post:
    rokibar (6th January, 2024), Weasel3 (7th January, 2024)
    dimon9555's Avatar
    Oct 2012
    Belarus
    Quote Originally Posted by rokibar View Post
    Just look at the sticker of the Kessy unit and see the word Continental there - to understand why the devices do not recognize this version
    3D0909137F 1000% Continental
    Kessy Continental -139D,-139E,-137F,-137G,7L0909135C,4E0907181 (-181A,-181С)--- (CS,Pin,MAC,Power class,ELV by dump),adaptation of any Kessy by dumps, Passat B6\B7 CCM adapt ELV without old,repair ССM in any state
  5. The Following User Says Thank You to dimon9555 For This Useful Post:
  6. #4
    Oct 2015
    Quote Originally Posted by dimon9555 View Post
    Yes its continental i write that. Any chance to get proper c.s. and pin code? I will try programming key via obd.
    Jun 2009
    hi,
    try one of these:
    cs: 03 B4 55 D2 D6 AA A8
    pin: 38765
    or
    cs: 11 DB D3 B4 F1 9D 1E
    pin: 24748
  8. The Following 2 Users Say Thank You to bradsystem For This Useful Post:
    ASCM (7th January, 2024), rokibar (7th January, 2024)
  9. #6
    Oct 2015
    Job done with friend helping.
    Thanks to all.
  10. #7
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by bradsystem View Post
    hi,
    try one of these:
    pin: 38765
    or
    pin: 24748
    Which sw u used to decrypt continental kessy
    Unit?
    Sent from my SM-A125F using Tapatalk
  11. The Following User Says Thank You to ASCM For This Useful Post:
    rokibar (8th January, 2024)
  12. #8
    Oct 2015
    Quote Originally Posted by ASCM View Post
    Unit?
    Thats not valid datas.
  13. #9
    Sep 2021
    NA
    Just a side thought, if you would restore original dump and create/learn key instead, would it
    a. Go into learning (correct pin)?
    b. Will the remote work right after learning?
    c. Crank after about 10 minute wait?
  14. #10
    Oct 2015
    With prepared key with right cs and with correct pin code you can programming key without any wait and remote will be programmed same time.
  15. #11
    Sep 2021
    NA
    So it would not go past “a”? Incorrect pin? The 10 min wait is due to lockout on some ecm after tinkering
  16. The Following User Says Thank You to vov4ik For This Useful Post:
    rokibar (16th January, 2024)
  17. #12
    HI !
    I have here one issue like yours
    Please let me know which tool did you use to make yours.
    Thank you !
  18. #13
    Oct 2015
    Quote Originally Posted by knok View Post
    HI !
    Thank you !
    Hi. friend send me proper datas i dont know which software used but not enough read eeprom with programmer.
  19. #14
    I use vvdi prog for these. Works very good.
  20. #15
    Oct 2015
    Quote Originally Posted by EMCE159 View Post
    Yes of corse. Me too. Forgot to say it must be wires read for proper immo data.
