Results 1 to 10 of 10
    Dec 2010
    Rotherham, UK
    Default Renault Medianav LAN5200WR4 Help
    I have a Renault LAN5200WR4 for repair. Is there a way to power it up on the bench to do some tests? I have a copy of the LAN5200WR1 service manual which lists all the pinouts but not sure what connections I need or if its possible to get it to power up out of the vehicle.
    Thanks Andy.
    Feb 2020
    Ukraina
    pin 6 +
    pin 7 -
    Dec 2010
    Rotherham, UK
    Which connector? As according to my pinouts 6 and 7 on the 12 pin connector are speaker outputs. If I put power on pin 5 batt it draws current when I press the front power button the screen remains dark/blank.
    Feb 2020
    Ukraina
    24 pin...............
    Feb 2020
    Ukraina
    12 pin
    5 +
    12 -
    Feb 2020
    Ukraina
    May need more amps
    Dec 2010
    Rotherham, UK
    This is the info I have for the 24 pin connector.
  8. The Following User Says Thank You to g1dtf For This Useful Post:
    fww1 (11th January, 2024)
    Feb 2020
    Ukraina
    Dec 2010
    Rotherham, UK
    When connecting 12v to pin 5 of the 12 pin connectotr and ground to chassis using a 3a supply, when I press the power button the set draws about 1a but the screen is dark. It may be that set is faulty going to get customer to put it in vehicle and see what it does. Thanks for your help.
  11. #10
    Mar 2021
  12. The Following User Says Thank You to maxiperez For This Useful Post:
    gabriel pablo (15th January, 2024)
