I'm working in this 1998 vehicle after 2 or 3 other mechanics tried before to repair some issues on the ETC. (Transmission Control)
They replaced:
2 transmissions
Transfer Case (AWD)
ETC Module
ABS Control
The vehicle still having the same issues as it's was since the beginning... (wasted money)
Now I have this car and already diagnosed by me with DAS.
The symptoms are:
After start the vehicle shift normal to 1rst - 2nd - 3rd gear, after that the tranny sets to SAFE MODE. Only one gear is engaged (I guess is 3rd)
After restart the engine, tranny goes back to normal.
Now the DTC's are the following.
ETC
008 R/P Lock actuator Y66/1
051 Gear implausible or transmission slipping
097
104 Sporadically R/P lock actuator
147 Sporadically gear implausible transmission slipping
After run some tests and actuation's, I saw that the tranny oil temp is set to -99 degrees, which means there is a fault or this tranny doesn't have temp sensor.
Also ME 2.0 (ECM) reports the dtc P0700 (Read ETC fault code memory)
ESP shows C1140 (Steering Angle Sensor N49 not initialized). I did the ZERO POINT reset after that.
After erasing all the codes and start a fresh test road only remain the ETC codes 008 - 104 - 147.
Some of the test performed.
Modulating Pressure Control Valve
ON 495 / 505
Shift Pressure Control Valve
ON 495 / 504
SHIFT VALVES
No fault Codes
Transmission oil Temp
-99 Celsius degrees
Any of you guys has a direction to follow? Thanks!!!
