Results 1 to 14 of 14
Thread: Soldering tips
    fuzz1's Avatar
    Jul 2019
    Default Soldering tips
    I would like to know what tips do you use for soldering irons.
    Is there some soldering tips that you have used and would recommend?
    I have been using a few from bought here and there but they do not last long. After 30 to 50 solder with a new soldering tip they are good for the bin.
    I have heard people using tips for more than six months daily and are still working fine.
    Where do you buy yours? What make would you recommend for the normal tips without heater element included.
  2. The Following User Says Thank You to fuzz1 For This Useful Post:
    pawl (3rd February, 2024)
  3. #2
    ricked's Avatar
    Apr 2016
    Europe
    use weller tips but of course you need a weller station, i work between 380 to 430 degrees every single day and my tips last for 6 months, also use tippy tip cleaner if there are blac/gray spots on tip
  4. The Following User Says Thank You to ricked For This Useful Post:
    fuzz1 (28th January, 2024)
  5. #3
    fuzz1's Avatar
    Jul 2019
    Thank you ricked. I don't have a Weller but I guess it will work on mine
  6. #4
    Mar 2020
    in the field
    hello they work well xytronic of course more expensive is better
  7. The Following User Says Thank You to pawl For This Useful Post:
    fuzz1 (1st February, 2024)
  8. #5
    fuzz1's Avatar
    Jul 2019
    Xytronic is very very expensive. Definitely out of my reach. Thank you. I might try a Weller or just use a hakko
  9. #6
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by fuzz1 View Post
    these are below the 100 euro for a soldering station.....
  10. #7
    fuzz1's Avatar
    Jul 2019
    Xytronic from eBay new above usd500.
  11. #8
    ricked's Avatar
    Apr 2016
    Europe
  12. The Following 3 Users Say Thank You to ricked For This Useful Post:
    fuzz1 (2nd February, 2024), pawl (3rd February, 2024), wuza (11th February, 2024)
  13. #9
    Mar 2020
    in the field
    I bought an LF1700 Xytronic 150 euro 100W super works ,I still have a 68-3C is 15 years old and still works
  14. The Following User Says Thank You to pawl For This Useful Post:
  15. #10
    mexanico1971's Avatar
    portugal
    Hi have a clone of JBC , width tip245 , you can use original tips
    The name is Aixum https://www.youtube.com/watch?v=Ds2Xq3dwV30&t=135s
    My work is my life ART TECH GARAGE
  16. The Following User Says Thank You to mexanico1971 For This Useful Post:
  17. #11
    fuzz1's Avatar
    Jul 2019
    I bought some tip tinner a long time back but thought it would not be of great use. I was pleasantly surprised using the tip tinner. Ended up coating the tip very nicely and the tip works again
  18. The Following 2 Users Say Thank You to fuzz1 For This Useful Post:
    p1et (10th February, 2024), pawl (11th February, 2024)
  19. #12
    Dec 2020
    I use a Weller WD1 with an WP80 pen with about 8 different tips, plus the 50w hot tweezers. Also use an Aixun T3A with 4 different 200w tips. As for a de-soldering gun I’ve got the one from Hakko. And also use tip tinner, flux, different solders including low melt etc. Hot air also from Weller. A digital microscope from Andonstar on a 32” monitor. That gets all my jobs done ranging from PCB repair, connector repair, IC swaps and problematic soldering with large heat sinks.
  20. The Following User Says Thank You to CasMo For This Useful Post:
    fuzz1 (12th February, 2024)
  21. #13
    Jun 2013
    I use for soldering ST 50D from toolcraft, hot air gordach 820 for 10 years, but the accessories are important...
    flux, cleaning sponge, tip restoration paste, but the important thing is, Setting the temperature!!!!
  22. #14
    Bosna
    Best solder wire is Sn60Pb40 type, solder wire with flux.
