Results 1 to 7 of 7
    Jun 2019
    France
    Default Immo off or clone audi a5 0261201963 bosch MED17.5
    Hello every body,
    Audi A5 / bosch MED17.5 / 0261201963 / 8T0907115A
    with Ktag
    I have a mapping problem on my calculator, starts but ignition problem here is the dump in calculator1 (origine from car).
    I wanted to write my eprom on a second-hand calculator 2. The second calculator does not start the car at all. Can you repair calculator 1 originally or immo off on calculator 2.
    Thank you.
    Hayssam1's Avatar
    Germany
    Quote Originally Posted by katineau View Post
    Hello every body,
    with Ktag
    Thank you.
    orgi old info
    VIN: WAUZZZ8T89A001515
    CS: F42A3B31E19175
    MAC: FF431D98
    PIN: 60194
    Please Press Thanks Button and Reput if i helped !
  3. The Following 5 Users Say Thank You to Hayssam1 For This Useful Post:
    katineau (2nd February, 2024)
    Jun 2019
    France
    I download it in calculator 1?
    Jun 2019
    France
    Quote Originally Posted by Hayssam1 View Post
    orgi old info
    CS: F42A3B31E19175
    MAC: FF431D98
    PIN: 60194
    Vin number is ok.
    I loaded the "neu eeprom sam" file into calculator 2.
    The car starts for 2 seconds then stops.
    DTC:
    P164700
    U030200
    P157000.
    Hayssam1's Avatar
    Germany
    Vin number is ok.
    DTC:
    P164700
    U030200
    P157000.
    I have eeprom and flash immo off for you, you can test and let us know
    immo off
    calculator2
    Jun 2019
    France
    Hello
    The car starts well.
    But still ignition problem.
    I think there is a problem in the engine, thank you very much for your help.
    kuebk's Avatar
    Feb 2016
    What issue do you have exactly? Any DTCs?
    VAG immo solutions (clone, immo off, repair) MEDC17, SIMOS, SDI, BCM2, ELV, DQ/DL/VL gearboxes, INVCON, MED9.x crypto
