Results 1 to 9 of 9
    alex_r_2001's Avatar
    New Jersey ,, USA
    Default 2020 Cadillac Escalade remove active fuel management
    Hello need to remove Active Fuel Management (AFM Displacement On Demand) , otherwise known as Cylinder Deactivation from this ecm... ECM was read with Hexprog
    i tried to read with ioterminal but was not able to connect with ecm...
    2020 Cadillac Escalade ESV Luxury
    Style / Body: SUV 4DEngine: 6.2L V8 DI
    Country of Assembly: United States
    Acdelco E92 ECM
    thankyou
    Solidarity with Ukraine
    New Jersey ,, USA
    tested solution help would be appreciated thanks
    Digital Under's Avatar
    Oct 2017
    ecu.design (Chevrolet (noMDS) - 12695228).bin
    GM FORD DODGE
    tuning - deleting - immo
  4. The Following User Says Thank You to Digital Under For This Useful Post:
    alex_r_2001 (8th February, 2024)
    New Jersey ,, USA
    Quote Originally Posted by Digital Under View Post
    Hello thanks alot .. ??? So just write back with hexprog and everything will be ok ????
    Jan 2014
    Usa
    Digital Under
    Are you able to switch off afm at camaro 3.6l 2016. This switching for 4 pistons make me crazy.
    Wysłane z mojego WP21 Ultra przy użyciu Tapatalka
    New Jersey ,, USA
    Default please remove afm
    hello it did not work .theft light is on ... i was able to read with ioterminal flash and eeprom seperately.... need afm removed thanks
    New Jersey ,, USA
    Anyone able to help ?? Thanks
    New Jersey ,, USA
    update
    Solved this thread can be closed......................................I was able to solve with help from another tuner......
    thanks for any help provided..
  10. #9
    New Jersey ,, USA
    No need for you to put a bad reputation on me. even though your file didn't work I still positively responded to you
    Digital under wrote on my reputation (this topic has already been closed Why bring it up again? no one is interested in your successes)
    I report on failures and successes.. Main reason I reported success is in the event somebody on this forum needs a file they know I have one available
