Results 1 to 14 of 14
    publiperro's Avatar
    Apr 2016
    Espaņa
    Default Clone dash golf vii d70f3537
    Hello, I have a problem with cloning a Golf VII GTI 5g1920756 instrument panel, I can read the microprocessor without problems, but when it comes to transferring the immo data from one to another, vvdi2 does not do it correctly, the panel mounted in the car It gives a component protection error and fazit, I have seen that poldiag can transfer everything without problems, could someone transfer the data to me and send me the correct file, I would pay for it, thank you.
    Something else, I tried to program with ODI online once the immo data was transferred with vvdi2 and it gave me this error.
    I need to start the car I would pay for the solution,its original dash does not turn on.
    publiperro's Avatar
    Apr 2016
    Espaņa
    Can anybody help me? thanks.
    Maartinj's Avatar
    Nov 2010
    you change immo, but fazit and CP stay old = data not match
    of course will failed
    Maartinj's Avatar
    Nov 2010
    if you clone to this same cluster - write whole data
    publiperro's Avatar
    Apr 2016
    Espaņa
    Yes I know that, but I don't know if vvdi2 does it for you, from what I see only poldiag does it, I would be willing to pay for the solution, you can help me.
    publiperro's Avatar
    Apr 2016
    Espaņa
    Quote Originally Posted by Maartinj View Post
    The problem is that its original reading was read with kd prog mini and when I turned the dash back on it went black and there is no way for it to work anymore, that's why I wanted to clone it with the flash of the donor dash, it's more copy the reading from the donor to the original and it turns on but with the donor's immo data.
    I don't know if there is a way to fix the original file so that the dash comes back to life.
    Maartinj's Avatar
    Nov 2010
    I can help you but no idea what file is from what cluster
  8. The Following User Says Thank You to Maartinj For This Useful Post:
    publiperro (21st February, 2024)
    publiperro's Avatar
    Apr 2016
    Espaņa
    Here I send you a copy of the original and a copy of the donor, the idea is to transfer data from immo data, fazit and cp to the reading of the donor, since with the reading of the original the dash is dead (all black)
  10. #9
    Maartinj's Avatar
    Nov 2010
    use test vvdi2 to copy data
    https://mega.nz/file/lI9XFaTI#PcSfzM...5igRDjrAo7UzFc
    do not use test vvdi2 to other functiuon
    soon xhorse will add this functions to officiall version
  11. The Following User Says Thank You to Maartinj For This Useful Post:
  12. #10
    publiperro's Avatar
    Apr 2016
    Espaņa
    Martin, thank you a million for your help, but I try to open the application on two computers and this happens to me, can you give me an idea of ​​what is happening?
  13. #11
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by publiperro View Post
    o.m.f.g........this is EXE file, not whole installation package
    copy that file to destination folder
  14. The Following User Says Thank You to Maartinj For This Useful Post:
    publiperro (22nd February, 2024)
  15. #12
    Apr 2024
    Hi, is this feature already included in the official version?
  16. #13
    Apr 2024
    So did you manage to clone the panel using the attached method?
  17. #14
    Oct 2014
    Netherlands
    I can do immo+CP transfers for MQB clusters (both classic and virtual).
    Contact me by PM if you are interested.
    Rgs H2Deetoo
