Results 1 to 7 of 7
    Jan 2023
    Default Blaupunkt Radio Code Changer?
    Hi all,
    I have a Blaupunkt CD43, BMW unit. I saw on MMHauto forum a post from long ago, for a blaupunkt code changer program but the user is long gone now and file requires a passcode, user claims he lost the code generator for this file....I have attached it in case someone can crack it?
    I want to ask, does anyone have this software? I want to change the 5 digit code in my radio to 11111 or something simple like that...00000 etc. I have the blaupunkt 4 digit code calculator but all of the North American region CD43 use 5 digit code, the 4 digit code does not interest me.
    If its possible to change the code, I can post the dump!
    Thank you.
    Below is the info sticker for the CD43 in case anyone wants it.
    I will also attach the "Blaupunkt CD43 Package" which include:
    CD43 programming manual
    CD43 Electrical schematic
    Blaupunkt Standard.exe - 4 Digit password generator
    Blaupunkt CD43 Internal Spare Parts Catalogue
  2. The Following User Says Thank You to Minnovations For This Useful Post:
    Hashim1 (23rd July, 2024)
  3. #2
    Raimax's Avatar
    Nov 2013
    LT
    Quote Originally Posted by Minnovations View Post
    Hi all,
    Thank you.
    I can change the code to whatever you want from 11111 to 66666
    I can also calculate your code from the sticker without the first code number. You will have to find the first number yourself
    x4452
    If you don't like it * close your eyes
    --- Geros dienos ! ---
  4. The Following 3 Users Say Thank You to Raimax For This Useful Post:
    Hashim1 (23rd July, 2024), Minnovations (22nd February, 2024), nihad69 (21st February, 2024)
  5. #3
    Jan 2023
    Quote Originally Posted by Raimax View Post
    x4452
    Can you change the two files attached to 11111
    thank you!
  6. #4
    Raimax's Avatar
    Nov 2013
    LT
    For one radio I changed. For other you will change yourself in the same way. Password in p.m.
  7. The Following User Says Thank You to Raimax For This Useful Post:
  8. #5
    Jan 2023
    x4452
    Raimax, your 5 digit North American code calculation from the sticker picture above is correct, I tested and first number is x=6, code is 64452.
    However just to let you know the E36 CD43 .bin I uploaded is not from this sticker, I do not know the 5 digit original code from this .bin
    But I do know the Europe code is 6341 for the .bin, and your modification code 11111 works as well. Interesting to note, when you changed the North American code to 11111, the original EU code 6341 still works.
    DigitalKaos forum is very slow to load right now.
    Any chance to know the original 5 digit code from the .bin? the serial is BP0273 2 9980177. I can guess the first digit again if you give me "x----"
    Original .bin attached again.
  9. The Following User Says Thank You to Minnovations For This Useful Post:
  10. #6
    Raimax's Avatar
    Nov 2013
    LT
    Eeprom stores two different codes so both work
    Code from dump 36323
  11. The Following 2 Users Say Thank You to Raimax For This Useful Post:
    Hashim1 (23rd July, 2024), Minnovations (23rd February, 2024)
  12. #7
    Jan 2023
    Code is correct, thank you
  13. The Following User Says Thank You to Minnovations For This Useful Post:
