Page 17 of 17 FirstFirst ... 7121314151617
Results 241 to 247 of 247
  1. #241
    Aug 2018
    I'm confused, what is the difference between RNS2 and MFD2?
  2. #242
    Oct 2018
    Quote Originally Posted by mad_mark View Post
    found it on another forum but i don't have the mfd2dvd myself so i didn't test it.
    NOTE:
    this firmware upgrade is designed for EUROPEAN MFD2 DVD units.
    how to:
    1. burn both images at LOW SPEED (2x-4x)
    2. turn ignition on and make sure there are no power supply interruptions (you can start the engine to have good current)
    3. press NAV button on your unit and put VWMFD2DVDEU0030.iso into MFD drive it will start to update the firmware - THIS MAY TAKE UP TO 30-40 MINUTES
    4. after update done press NAV again and put the UNLOCK CD. unlocking takes just a few seconds the screen will show progress bar in a loop but once it completes single cycle it is safe to remove the disk from unit.
    after that you should be ready to use self burned DVD+R DL disks however you still need to burn them on GOOD QUALITY DISKS AND AT LOW SPEEDS (2x). this has been tested with the VW EUROPE v7 MAP and reported to work ok (still, i didn't test it myself).
    TEST THIS AT YOUR OWN RISK!!!
    thanks to billboard and Hilleri for helping with unlock procedure
    I tried to do it but it tells me CD is not readable
  3. #243
    Jan 2019
    Hello everyone,
    I'm upgrading to v.19 of the RNS2 DVD (7L6035177E) and I'm afraid I'll be prompted for the radio code I do not know what it is.
    Someone can help me?
    The radio has the following ID: VWZ1Z7F6489715.
    Thank you very much.
  4. #244
    Mar 2019
    Hi my car is a Touareg 2006 with mfd2 dvd. It was already unlock and i was using version firmware 0728 and the v16 maps worked fine.
    I,ve tried with the magnet to update to version 0730 but started ok and then stopped with no version to load (see atached jpg).
    The last firmware is erased and now no Nav is in the unit.
    any idea?
    Anybody has a link to only the firmwaHi my car is a Touareg 2006 with mfd2 dvd. It was already unlock and i was using version firmware 0728 and the v16 maps worked fine.
    any idea?
    Anybody has a link to only the firmware 0730 or 0728 .
    re 0730 or 0728 .
  5. #245
    Feb 2020
    thanks hope it works great
  6. #246
    Jul 2019
    Germany
    Quote Originally Posted by vg_alex View Post
    Unlock software compatible with all FW versions
    it is compatible with this RNS2 sw version?
  7. The Following User Says Thank You to christensen For This Useful Post:
    fsdgfsdagfasd43 (10th November, 2023)
  8. #247
    Mar 2024
    can you upload again whole unlock acrhive? thanks in advance
