anyone can post a video when insert a CD to unlock?
today i re-try to burn a dvd...
DVD DL verbatim, maps V7, clone dvd2, pioneer 110D 1x speed...
insert dvd... MFD2 say "DVD not correct"
where I mistake???
Anyone knows if this firmware works on the MFD2 CD version also.
I know it allready works on DVD
No luck here.
Also tried on a verbatin 8x dvd+r dl at 2.4x
Upgrade to sw3.0 and unlock worked fine!
I am using a Lite-On LH-20A1S and Nero / Alcohol 120%
What am i doing wrong?
@tinus
Try CloneCD with 1x or 2x...for me works!
Ok, i will trie using CloneCD.
I have a MFD2 version B (without the silver buttons). Is there a difference between version B and C? Has anyone succesfully unlocked a version B?
i've update the firmware succesfull at V30
insert an unlock cd...
but the map dvd return me error "dvd not compatible"
I try with alchol120%
kb3 (linux)
nero burning 7
and now I'm waiting to the clone cd finish the last one...
every time at the max slow speed possible...
EDIT: another dual layer ****ed!
yesssss , you are great , firmware upgrade => unlock => map V7 on MFD2 B and..... works fine !!!
Pioneer DVD writer DVR 212D
Maps : Verbatim DVD-R DL imageburn at 2x
Unlock : Verbatim azo cd-r imageburn at 1x
Firmware : Verbatim azo cd-r imageburn at 1x
I hope can be useful these information
many thanks to all
No succes with CloneCD at 1x on a verbatim dvd+r dl
Is my problem:
- the dvd burner (a lite-on LH-20A1S)?
- the downloaded v7 map?
- versioning: HW-HU D1/0730
Platform OPL3.0v49P26 / 070411
Navi NV_5.2C7P1 / 051116
Is there a way to check if the unlock firmware is succesfully applied?
Yes unlock seems to work fine, yellow progress bars very quickly in a endless loop.
Switching on and off the MFD does not matter.
I have been reading a german forum, seems al lot of users have good results with a LG burner...
I tried a Lite-on, samsung and a sony with no succes. Al runs on low speed (2.4x) and a verbatin dvd+r dl with different burning tools (Nero, Alcohol, CloneCD and ImgBurn).
Have read this post. Am trying to update my MFD2 as well. It is now still original with 2005 maps.
Well if I need some help I'll be asking for it.
Greetz!
Thanks to all of you and especially the guy who started it all. I managed to burn successfully the v7 map with clonecd 2.4x on a verbatim dvd+dl. However I would like to ask if anyone knows whether maps could be modified to be used with the MFD2. More specifically I need a map of Bulgaria to be used with the MFD2. This information will probably also be interesting to people from serbia, croatia, romania and so on who own the MFD2 navigation but do not benefit from using the comlete map services in their countires. Thank you in advance!
