    motor25's Avatar
    Dec 2015
    Belarus
    Default Ford Fusion 1.4HDi Siemens SID 804 EGR OFF
    Hi to all! Please need tested solution EGR OFF Ford Fusion 1.4HDi Siemens SID 804!
    Feb 2016
    United Kingdom
    Quote Originally Posted by motor25 View Post
    here is your file
    ask for pass in PM
    Pass = Thanks + Reputation
  3. The Following User Says Thank You to BmwMerc For This Useful Post:
    motor25 (4th March, 2024)
    motor25's Avatar
    Dec 2015
    Belarus
    Not solved, no pass, still need a solution!
    Feb 2016
    United Kingdom
    be patient mate. not everybody can sit hours in the forum, some people are busy.
    Your PM been replied. check inbox
    motor25's Avatar
    Dec 2015
    Belarus
    This solution does NOT work! File made by ADS EGR remover, even though the file is in Siemens format! Have you checked file?
    Feb 2016
    United Kingdom
    Tne file should work as it is tested solution.
    And you are wrong the file wasn't made by ADS EGR remover as I don't have it and to be honests don't know what it is
