Results 1 to 4 of 4
    Mar 2020
    Default 0261200413 Immo off - Bmw 325i
    the car is a '93 325i single vanos
    the old ecu is water damaged, so i bought a new one:
    0 261 200 413
    software version 358 715
    is possible to do a immo off on this ecu?
    i attached the dump
    fluxxy's Avatar
    Nov 2020
    if you have put red label 413 on the car you can cut wire 66 from ecu and should run
    Mar 2020
    Quote Originally Posted by fluxxy View Post
    no, i only have the new one wich is a '95 silver label. the car does not start with it..
    Mar 2020
    i also tested the eprom from the old red label in the new silver but the car does not start, problably the software is not compatible
