Hi !
I have a Delphi-Grundig CD30 MP3 and a Siemens VDO DVD90 and need the security codes from the EEprom.
Hi !
cd30 sec code is 3108
Baggam (24th March, 2024)
Baggam (24th March, 2024), Mankyro (24th March, 2024), petronijul (24th March, 2024)
Cool !! Thanks so much !!
Display and DVD90 are married in my Zafira.
I want to install my friends CD-30 to update and code to AUX, then reinstall my DVD90.
Is that possible ? I guess I need the DVD90 code to remove it, or ?
IMG_7107.jpgHi, can anybody help wita code for my Vauxhall corsa? I have a touch and connect radio,
Serial number: 3144242
device number: 7612830172
date: 13.07.12
Ste201079 (24th March, 2024)
Hi wbr !
I did as you suggested. Before it was 'display safe' .
Programmed with the virgin dump I got 'radio safe' and beeping.
I tried to activate with 0108, programming successful, unit reset, but still 'radio safe' and beeping. :-/
What did I do wrong ... .. or does my Op-Com not work correctly ?
Attached Eeprom dump now.
Thanks so much !!
still having no luck
Hi shooting !
.. sorry about the wbr ...
There was something about not being natively English speaking ...
I am using a chinaclone of OP-COM 1.70 with VAUX-COM 120309a.
Repeated (again) as you suggested.
Programmed CD-30 with your virgin dump : 'CD-30-Menke-virgin.bin'
Verified eeprom OK
Connected CD-30 to car.
I got 'radio safe' and beeping ...
Check that there are no trouble codes for DIS and EHU.
Check correct setting of M-CAN.
Activate EHU with 0108 -> programming successful -> unit reset,
... but still 'radio safe' and beeping.
After that dumped the EEprom again : 'CD-30-Menke-cannot.pair.beeps.2.bin'
compared with last time dump 'CD-30-Menke-cannot.pair.beeps.bin'
It is nearly the same as last time ... very strange.
origin : 03E0 00 FE 00 00 00 00 00 00 96 3E 4E 62 E7 8A A0 00 (Display safe)
virgin : 03E0 00 FE 00 00 00 00 00 00 A5 0F 7E 5A 7E A5 5F 00 (Radio safe)
after : 03E0 00 FE 00 00 00 00 00 00 95 3E 4E 62 97 FE 5F 00 (Radio safe)
Attached screenshots and dumps.
Thanks for your support !!!
Albert G (25th March, 2024)
Yes original car display and DVD90. Which OP-COM SW would you recommend ?
